!!burn xgd3 to any dvd+r dl!! not my tut!!
  • djjwdubz
    • 1011
    #46
    i have found a better way to burn and pass!!! let me no if you want it!!
    this one is edited fw so the disk burns at 2.4 speed for aone and any other. i got all mine done from the new way 100%!!!
    • DAVE466
      • 115
      #47
      mine burns but fails at verivication at same point. Tried the settings but with no joy.
      the game shows up on xbox but when ya load it, it just stays with the loading mark on it arrow going round
      I 12:35:36 ImgBurn Version 2.5.6.0 started!
      I 12:35:36 Microsoft Windows 7 Ultimate Edition (6.1, Build 7601 : Service Pack 1)
      I 12:35:36 Total Physical Memory: 2,030,904 KB - Available: 1,263,088 KB
      I 12:35:36 Initialising SPTI...
      I 12:35:36 Searching for SCSI / ATAPI devices...
      I 12:35:37 -> Drive 1 - Info: ATAPI iHAS124 B AL0S (G (RAID)
      I 12:35:37 Found 1 DVD?RW/RAM!
      I 12:36:37 Operation Started!
      I 12:36:37 Source File: D:\Xbox Games\Pro Evo 12\Pro Evolution Soccer 2012-XGD2-CS.dvd
      I 12:36:38 Source File Sectors: 3,827,488 (MODE1/2048)
      I 12:36:38 Source File Size: 7,838,695,424 bytes
      I 12:36:38 Source File Volume Identifier: 13599
      I 12:36:38 Source File Volume Set Identifier: ceee8000MS UDFBridge
      I 12:36:38 Source File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
      I 12:36:38 Source File Implementation Identifier: Microsoft CDIMAGE UDF
      I 12:36:38 Source File File System(s): ISO9660, UDF (1.50)
      I 12:36:38 Destination Device: [2:0:0] ATAPI iHAS124 B AL0S (G (RAID)
      I 12:36:38 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67)
      I 12:36:38 Destination Media Supported Write Speeds: 4x, 6x, 8x
      I 12:36:38 Destination Media Sectors: 4,267,040
      I 12:36:38 Write Mode: DVD
      I 12:36:38 Write Type: DAO
      I 12:36:38 Write Speed: 4x
      I 12:36:38 Link Size: Auto
      I 12:36:38 Lock Volume: Yes
      I 12:36:38 Test Mode: No
      I 12:36:38 OPC: Yes
      I 12:36:38 BURN-Proof: Enabled
      I 12:36:38 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
      I 12:36:38 Book Type Setting: DVD-ROM
      I 12:36:38 Advanced Settings - Force HT: Yes, Online HT: No, OverSpeed: No, SmartBurn: Yes
      I 12:37:07 Optimal L0 Data Zone Capacity: 1,913,760
      I 12:37:07 Optimal L0 Data Zone Method: Copied From Original Disc
      I 12:37:09 Set L0 Data Zone Capacity Succeeded!
      I 12:37:11 Filling Buffer... (20 MB)
      I 12:37:15 Writing LeadIn...
      I 12:37:17 Writing Session 1 of 1... (1 Track, LBA: 0 - 3827487)
      I 12:37:17 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3827487)
      I 12:37:17 Writing Layer 0... (LBA: 0 - 1913759)
      I 12:49:09 Writing Layer 1... (LBA: 1913760 - 3827487)
      I 13:01:03 Synchronising Cache...
      I 13:01:06 Closing Track...
      I 13:01:07 Finalising Disc...
      I 13:01:41 Exporting Graph Data...
      I 13:01:41 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\ATAPI_iHAS124_B_AL0S_19-JANUARY-2012_12-36_RICOHJPN-D01-67_4x.ibg
      I 13:01:41 Export Successfully Completed!
      I 13:01:41 Operation Successfully Completed! - Duration: 00:25:03
      I 13:01:41 Average Write Rate: 5,371 KB/s (3.9x) - Maximum Write Rate: 5,728 KB/s (4.1x)
      I 13:01:41 Cycling Tray before Verify...
      W 13:01:49 Waiting for device to become ready...
      I 13:02:03 Device Ready!
      I 13:02:04 Operation Started!
      I 13:02:04 Source Device: [2:0:0] ATAPI iHAS124 B AL0S (G (RAID)
      I 13:02:04 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: RICOHJPN-D01-67)
      I 13:02:04 Source Media Supported Write Speeds: 4x, 6x, 8x
      I 13:02:04 Image File: D:\Xbox Games\Pro Evo 12\Pro Evolution Soccer 2012-XGD2-CS.dvd
      I 13:02:04 Image File Sectors: 3,827,488 (MODE1/2048)
      I 13:02:04 Image File Size: 7,838,695,424 bytes
      I 13:02:04 Image File Volume Identifier: 13599
      I 13:02:04 Image File Volume Set Identifier: ceee8000MS UDFBridge
      I 13:02:04 Image File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
      I 13:02:04 Image File Implementation Identifier: Microsoft CDIMAGE UDF
      I 13:02:04 Image File File System(s): ISO9660, UDF (1.50)
      I 13:02:04 Read Speed (Data/Audio): MAX / MAX
      I 13:02:05 Verifying Session 1 of 1... (1 Track, LBA: 0 - 3827487)
      I 13:02:05 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 3827487)
      I 13:02:05 Verifying Layer 0... (LBA: 0 - 1913759)
      W 13:13:12 Miscompare at LBA: 1304000, Offset: 0
      W 13:13:12 Device: 0xBB
      W 13:13:12 Image File: 0x57
      W 13:13:12 Total Errors in Sector: 2,026
      I 13:13:12 Verifying Sectors...
      W 13:13:18 Miscompare at LBA: 1304001, Offset: 0
      W 13:13:18 Device: 0xE0
      W 13:13:18 Image File: 0x5B
      W 13:13:18 Total Errors in Sector: 2,036
      I 13:13:19 Verifying Sectors...
      W 13:13:20 Miscompare at LBA: 1304002, Offset: 0
      W 13:13:20 Device: 0x52
      W 13:13:21 Image File: 0x81
      W 13:13:21 Total Errors in Sector: 2,041
      I 13:13:21 Verifying Sectors...
      E 13:13:22 Miscompare at LBA: 1304003, Offset: 0
      E 13:13:22 Image File: 0x03
      E 13:13:22 Total Errors in Sector: 2,039
      E 13:13:22 Failed to Verify Sectors!
      I 13:13:23 Exporting Graph Data...
      I 13:13:23 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\ATAPI_iHAS124_B_AL0S_19-JANUARY-2012_12-36_RICOHJPN-D01-67_4x.ibg
      I 13:13:23 Export Successfully Completed!
      E 13:13:23 Operation Failed! - Duration: 00:11:17
      I 13:13:23 Average Verify Rate: 3,857 KB/s (2.8x) - Maximum Verify Rate: 13,790 KB/s (10.0x)
      I 13:17:17 Operation Started!
      I 13:17:17 Source Device: [2:0:0] ATAPI iHAS124 B AL0S (G (RAID)
      I 13:17:17 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: RICOHJPN-D01-67)
      I 13:17:17 Source Media Supported Write Speeds: 4x, 6x, 8x
      I 13:17:17 Image File: D:\Xbox Games\Pro Evo 12\Pro Evolution Soccer 2012-XGD2-CS.dvd
      I 13:17:17 Image File Sectors: 3,827,488 (MODE1/2048)
      I 13:17:17 Image File Size: 7,838,695,424 bytes
      I 13:17:17 Image File Volume Identifier: 13599
      I 13:17:17 Image File Volume Set Identifier: ceee8000MS UDFBridge
      I 13:17:17 Image File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
      I 13:17:17 Image File Implementation Identifier: Microsoft CDIMAGE UDF
      I 13:17:17 Image File File System(s): ISO9660, UDF (1.50)
      I 13:17:17 Read Speed (Data/Audio): MAX / MAX
      I 13:17:18 Verifying Session 1 of 1... (1 Track, LBA: 0 - 3827487)
      I 13:17:18 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 3827487)
      I 13:17:18 Verifying Layer 0... (LBA: 0 - 1913759)
      E 13:22:31 Miscompare at LBA: 1304000, Offset: 0
      E 13:22:31 Device: 0xBB
      E 13:22:31 Image File: 0x57
      E 13:22:31 Total Errors in Sector: 2,026
      E 13:22:31 Failed to Verify Sectors!
      I 13:22:32 Exporting Graph Data...
      I 13:22:32 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\ATAPI_iHAS124_B_AL0S_19-JANUARY-2012_13-17_RICOHJPN-D01-67.ibg
      I 13:22:32 Export Successfully Completed!
      E 13:22:32 Operation Failed! - Duration: 00:05:13
      I 13:22:32 Average Verify Rate: 8,358 KB/s (6.0x) - Maximum Verify Rate: 13,760 KB/s (9.9x)
      • djjwdubz
        • 1011
        #48
        This will fix it!!!! patch your games with this link http://www.digital-kaos.co.uk/forums...atches-249106/
        then flash your ihas with this edited c4evas fw iHAS-124B-AL0S-MKM001MKM003-final_AONE+RITEK+MKM003x2speed.bin then restart your pc or laptop, this is for ihas 124b.
        Then
        Open IMGBurn and go to TOOLS>SETTINGS>WRITE. Clear the box that Performs OPC Before Write. Then go to TOOLS>SETTINGS>I/O and click Page 2 tab. Move buffer size between 71-73mb, Main Buffer Threshold to 25%, and Device to 50%. Press Ok
        Prepare to burn (Write Image File To Disc). On this page you can change the setting to burn at 2.4x and advanced settings (settings area bottom-right of the three icons in that area). Go to Lite-On tab...In the Change For: dropdown-list you will disable Forced HyperTuning, Online HyperTuning, and OverSpeed. If not enabled, Enable SmartBurn. Press OK.
        Burn your XGD3 and verify. It should verify at 100%.
        This will fix it. the fw i posted is mine with my own link so i knwo its safe!! if you think its not safe do not use it.
        all the edited fw does is lets aone and ritek disks burn at 2.4 speed, this will not ~~~~ your drive up. all dvd burners can burn at 2.4 speed, its just as good as c4s fw!
        this will work for everyone, if you dont have a ihas124b pm me and i will edit the other fws so that these disks work for that burner!!!
        • djjwdubz
          • 1011
          #49
          Originally posted by saj1985
          yes this what i used,
          but make sure with imgburn you 'run as administrator'
          no need for that now bro!!!
          • DAVE466
            • 115
            #50
            will give it a try. the game that i was writing was pro evo 12 which isn't in the list of patches?
            • djjwdubz
              • 1011
              #51
              thats a non ap2.5, you dont need the patches for that. you can use a normal burner for that. i done that game last night.
              • DAVE466
                • 115
                #52
                I've just done as said and burnt it at 2.4 and it says reading then open tray?? Any ideas now?
                • djjwdubz
                  • 1011
                  #53
                  what dashboard you got? have you got 3.0?
                  • DAVE466
                    • 115
                    #54
                    aye on the new dash and flashed with lt3.0 mate.
                    • cunny
                      • 4915
                      #55
                      Cheap media Run a burnt iso through KPROBE and see the results for yourselves.
                      Max PI Should not be higher than 100 and PFI should be no higher than 4. If higher on some machine then can run.
                      I have seen discs like aone fail badly with the same settings i use for verbs. Same reason i posted a while back. The outter ring of the disc, you know the 1 conventional burners wont use? Well its used to burn XDG3.
                      Try the settings i posted the other night with a verb. Run through Kprobe and see if they pass
                      • dragazar
                        • Apr 2011
                        • 59
                        #56
                        My aone golds burn at 4x no errors after verify all fine. odd disc dont work but at least 90% of them work at 4x with c4eva firmware from latest packon ihas124b
                        Any other tools i can use to verify the image on my disc after it has been verfied by IMGBURN ??
                        Last edited by dragazar; 21 January, 2012, 08:53. Reason: Any other tools i can use to verify the image on my disc after it has been verfied by IMGBURN ??
                        Click thanks if i helped by asking a good question or helped
                        • speedracermm
                          • Feb 2012
                          hello can anybody help me plz? i used djjwdubz FW but imgburn writing leadin and nothing else happens. i use maxell dl(ritek) external writer ihas 124b,win7
                          thx
                          • djjwdubz
                            • 1011
                            #58
                            what media id is the dvd you are using? it might not be the same as the id i edited.
                            • bigvdaking
                              • Feb 2012
                              tru
                              if u flash the 124 b u can burn the cheap ones and they burn at 4 speed 100 percent every time
                              • djjwdubz
                                • 1011
                                #60
                                what disks you using?
