can't select portIO - jungleflasher 1.55b
  • cunny
    • 4915
    #16
    Originally posted by funkysy
    now i've done a complete systrem install and deleted everything of the harddrive and restarted but i'm still gettin the same error with hitachi drive only ram upload execute failed
    x86 (32bit) x64 (64 bit) ?
    • funkysy
      • 105
      #17
      it's 32 bit, but i'm going to try some differen driver and see if that works?
      at the moment once i send mode b and then dump, it seem it's going for it but after 3-4 dots then stop with the error!!!!!!!
      • cgscott
        • 3513
        #18
        Try different ports on the via card.
        Patience is a virtue.
        • funkysy
          • 105
          #19
          i've try differen drivers and ports still nothing, i flashed a benq and samsung the other day it's fine with them but hitachi! it's not having it.
          before when it was working, i was running on vista ulimate and at the moment i on vista home, do you thing that could be the problem?
          as you can see everything looks fine
          • cunny
            • 4915
            #20
            I can see your drivers for VIA card are disabled/deleted. Reinstal and enable them!
            Also new version of jungleflasher out, uses a differant method for port i/o driver. Give that a try
            • funkysy
              • 105
              #21
              reinstall drivers and enable, now the PC see the dvd drive,
              as you can see but with this error.
              and error ram poke failed was happening aswell!!!!!!!!
              why? why?
              • cunny
                • 4915
                #22
                Now try another port on the via card. also you could try the classic mode on a 47
                • showstopper
                  • 64
                  #23
                  My jungleflasher works with the VIA drivers uninstalled. In fact JF recommend that you remove the drivers.
                  It has to be enabled though.
                  • funkysy
                    • 105
                    #24
                    THANK YOU for your help, i've got it sort now, i'l reinstall and manully install a hack via driver, left it in drivers folder, then i change port on and working fine now..
                    so a big thanks to Cunny and cgscott for your help
                    • cunny
                      • 4915
                      #25
                      The only drive you need to remove drivers for is a liteon, this is due to the liteon freeze with the drivers. Thats only when using a VIA Card.
