When you put the x clamps back on the error is 1 red light/E74 on screen.Reason for it going to 2 red lights with the x clamp fix kit on is that its over heating striaght away.
Dont use 3 washers as stated above or try heat guns or towels.
Best way i have found is to use 2 M5 washers on the GPU under the heatsink.If yours goes back to 1 red light with the 2 washers on,leave the fan disconnected and wait for it to go to 2 red lights and then turn it off.Wait about 10 mins and reconnect the fan and all should be ok"green lights"
