best discs to burn 360 games with
  • rigga
    • Sep 2009
    • 102
    wot are the best discs to burn my 360 games that ive downloaded? keep gettin dirty discs error and wirte errors
  • cgscott
    • 3513
    I have used just about every Dual layer disk there is and i get no throwaways.
    Get a good burner and use IMGBURN at AWS for speed to burn this auto selects the write speed as disks can vary in quality.
    I have had minimal throwaways over thousands burned.
    Im using these to test and so far 20 burnt 20 good.
    Patience is a virtue.
    • kris9000
      • Apr 2009
      • 121
      i would only ever use verbatems dual layer. never had a bad burn yet
      • cheeezo
        • 5
        verbatim mate
        • manutd4life
          • 132
          is your drive an hitachi? your laser may be on its way out, you can get them for a 5er.
          i have only ever used verbs burnt with imgburn @x2.4
          never had a problem with them but i have 3 lasers on the way to me for my consoles so ill be back on that soon
          • phattsambo
            • 4
            hi clone cd will burn ur duel layer discs ,the only real success is with v 5.2.9.1 if u use a pioner 112 drive external or internal dosent matter ,if u burn your games from an img file as long as ur games r on the computers hard drive u can burn at a good speed without any failure , but if u burn from an external hard drive u need to burn at 1 or 2 speed max, as for the best discs a company called misco do a printable disc in packs of 25 for about ?15 and i havent had a bad write yet , good luck
            • trance
              • Aug 2009
              • 223
              i always use verbatim , yes they are made in india, not singapore but haven't caused me any issues http://www.play.com/PC/PCs/-/992/124...archtype=genre
              • janobi
                • 1624
                Verbs are the best bar none.
                If you want good cheaper media, then I would suggest elite or aone premium disks. Both are good cheap alternatives.
                Dont know what the dude is on about with clone only working with one version, mine is the most upto date, and burns stuff fine.
                • Scarface
                  • 92
                  Verbatim DL all the way, on a Pioneer 112D, using clonecd 500+ games burnt, not 1 coaster!
                  • showstopper
                    • 64
                    Arita Ritek for me. No bad burns run on all drives and ?10 for 25.
