hi clone cd will burn ur duel layer discs ,the only real success is with v 5.2.9.1 if u use a pioner 112 drive external or internal dosent matter ,if u burn your games from an img file as long as ur games r on the computers hard drive u can burn at a good speed without any failure , but if u burn from an external hard drive u need to burn at 1 or 2 speed max, as for the best discs a company called misco do a printable disc in packs of 25 for about ?15 and i havent had a bad write yet , good luck
