Plug it into the sata closest to the front of your PC. Also the benq does not need half tray open.
All you need to do is Intro device. Power of and on quickly. It will the give you 0x73 status meaning it is seen. Click read then load new benq firware into JF. Spoof key over. Click Write. Then it will write and verify write.
Then click Outro Device. And this returns the drive back to normal status.
Test the drive by ejecting if it does then it is done proper. I usually read the drive again to check the flash.
The new benq LT 1.1 will show as Stock drive once flashed over and make sure your key is spoofed.
