Hi all,
With the help of this forum I finally got round to flashing my 360. It all went fine, was easy to do. I was looking forward to playing Borderlands. Burnt a copy, put it in and nothing. I figure it was because I was using rubbish discs so got some verbatims and the same happened again. Decided to try a different game but same thing.
I have ran the disc and the iso through abgx and they are fine, I have the layer break etc and am using IMGBurn. I have tested someone elses backups and they play fine in my console so I have no idea what the problem is.
I don't know if this helps but after I have finished burning the disc this is the info I get on IMGBurn:
Slimtype BD E DS4E1S ES21 (ATAPI)
Current Profile: DVD+R DL
Disc Information:
Status: Complete
Erasable: No
Sessions: 1
Sectors: 3,827,488
Time: 850:35:13 (MM:SS:FF)
Supported Write Speeds: 2.4x, 4x
DVD?R DL Boundary Information:
L0 Data Zone Capacity: 1,913,760
Changeable: No
TOC Information:
Session 1... (LBA: 0)
-> Track 01 (Mode 1, LBA: 0 - 3827487)
-> LeadOut (LBA: 3827488)
Disc Control Blocks Information:
Slimtype
Physical Format Information (ADIP):
Disc ID: MKM-003-00
Book Type: DVD+R DL
Part Version: 1
Disc Size: 120mm
Maximum Read Rate: Not Specified
Number of Layers: 2
Track Path: Opposite Track Path (OTP)
Linear Density: 0.293 um/bit
Track Density: 0.74 um/track
First Physical Sector of Data Area: 196,608
Last Physical Sector of Data Area: 16,580,607
Last Physical Sector in Layer 0: 2,283,519
Physical Format Information (Last Recorded):
Disc ID: MKM-003-00
Book Type: DVD-ROM
Part Version: 1
Disc Size: 120mm
Number of Layers: 2
Last Physical Sector of Data Area: 16,580,575
Last Physical Sector in Layer 0: 2,110,367
Layer Information:
Layer 0 Sectors: 1,913,760 (50%)
Layer 1 Sectors: 1,913,728 (50%)
Performance (Write Speed):
Descriptor 1...
-> B0: 0x00, B1: 0x00, B2: 0x00, B3: 0x00
-> EL: 3827487 (0x003A671F)
-> RS: 8,310 KB/s (6x) - WS: 3,324 KB/s (2.4x)
Descriptor 2...
-> RS: 8,310 KB/s (6x) - WS: 5,540 KB/s (4x)
Does that all look right or am I doing something wrong?
Am I needing a new burner? if so is this one any good:
LG GE20NU11 8x DVDRW DL & RAM Hi-Speed USB - Retail Black - Ebuyer
Any help anyone can give here is very much appreciated, so much I want to play but just haven't been able to!
Thanks for reading!
Disc Information:
Status: Complete
Erasable: No
Sessions: 1
Sectors: 3,827,488
Changeable: No
TOC Information:
Slimtype
Disc ID: MKM-003-00
Book Type: DVD+R DL
Part Version: 1
Disc Size: 120mm
Number of Layers: 2
Disc ID: MKM-003-00
Book Type: DVD-ROM
Part Version: 1
Disc Size: 120mm
Number of Layers: 2
Layer Information:
Descriptor 1...
Descriptor 2...
Thanks for reading!
