Help needed please
  • m9g
    • 704
    Help needed please
    I'm a noobie at this and have just flashed my drive which is fine and this is the first attemp at a game, I tried 1 method of running through abgx and then loading the .dvd in imgburn and that wouldnt work in console and then converted to ssv2 and used xbc to burn and that also didnt work
    Please what am I doing wrong or am I doing right and theres another prob?
    Regards
    DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
  • cgscott
    • 3513
    What did it say when you put the disk in the console. What drive did you flash and did you put the latest firmware on it? Also did you spoof the key over to the new firmware before flashing?
    Patience is a virtue.
    • m9g
      • 704
      Hi it's the hitachi drive and flashed with ixtreme 1.51.
      When put disc in I can hear it spinning up and console says reading and then just stops and goes to the 360 homepage bit with the open tray etc etc
      Spoofing key? I followed the youtube video for the hitachi drive in one of the sticky's on DK, put into mode B then flash ixtreme and thats it - used the connectivity kit
      • cgscott
        • 3513
        Ye sin Jungleflasher there is a tab once you have extracted orig firware at the top once you insert the hitachi 1.51 in the bottom tab click spoof to target. This will transfer the key from the orig.bin over to the ixtreme. Each drive has a key specific to the board so you must spoof it over in order for the new firmware to read.
        Small mistake but easily rectified. Flash again but remember to click spoof to source.
        • m9g
          • 704
          ok thanks so even though I have already flashed it without spoofing the key it will still be ok to do it again then?
          Also with reference to burning is it correct to open the file in abgx then open the .dvd in imgburn
          Regards
          • cgscott
            • 3513
            Yes it will be fine. Just load the orig bin in the top manually (the first orig.bin you pulled from the drive) Then ixtreme in the bottom. Spoof to target and it will be good to go.
            Yes open the iso in abgx it will run and patch. Then select the .dvd file in IMGburn. This will set layer break and burn.
            • m9g
              • 704
              thanx will try
              • shawlynot
                • Sep 2009
                • 32
                You never sed which disc's you are using.
                Likely hood is it's the laser, easy to fit but there are 2 types so you need to check which on you need.
                • m9g
                  • 704
                  I got them from c3k website where the connectivity kit came from - they were recommended on the site for 360 backups
                  • cgscott
                    • 3513
                    Did you sort the problem?
                    • m9g
                      • 704
                      doing it right now thanks so will let you know
                      • m9g
                        • 704
                        hmmm - key already matches top and bottom but when i restored to original i couldnt restore to my original coz i didnt save it but the iextreme firmware file came with loads of original fw so loaded the original for mine back in
                        When the original fw is saved does it save the key aswell - what i'm thinking is maybe the original fw that came with the iextreme file that i have installed has a different key - is this possible? or will the key for mine always stay the same?
                        Regards
                        • cgscott
                          • 3513
                          What is the key? If you didnt spoof the key over the first time its most likely going to be 77777777777777 etc but if you did it should be full of letter and numbers. So you need the orig firmware you pulled the first time. Always save your firmware. If you never and you flashed it wrong the first time you will not get the key for your drive back.
                          Copy the key and show me how it looks.
                          • m9g
                            • 704
                            I think i might have sussed it!!!
                            Didnt realise i had to click on the open target firmware and choose the iextreme firmware then click on spoof source target - i take it by doing this it patches the ixtreme file with my key before i load the fw into my drive
                            • cgscott
                              • 3513
                              Correct. Not sure what you were doing .
                              Will be fine once youve done that.
