found this and it works on xp pro for me
Increase Bandwidth By 20%
A nice little tweak for XP and Vista.
Microsoft reserves 20% of your available bandwidth for their own purposes (suspect for updates and interrogating your machine etc..)
Here's how to get it back:
Click Start-->Run-->type "gpedit.msc" without the "
This opens the group policy editor. Then go to
Local Computer Policy-->Computer Configuration-->Administrative Templates-->Network-->QOS Packet Scheduler-->Limit Reservable Bandwidth
Double click on Limit Reservable bandwidth. It will say it is not configured, but the truth is under the 'Explain' tab :
"By default, the Packet Scheduler limits the system to 20 percent of the bandwidth of a connection, but you can use this setting to override the default."
So the trick is to ENABLE reservable bandwidth, then set it to ZERO.
This will allow the system to reserve nothing, rather than the default 20%.
Note : Works on Vista Ultimate, XP Pro, 2000 but other o/s not tested.
if not press the green tab to tell me to f**Koff
Don't forget to do it
right place to share each other, not to
Don't do it when you sleep, will make big cost
