hi all my ip address shows 82.39.70.51 but i need something like 192.168 & so on for my dreambox how do i get the proper 1 as ive tried start run configip & it flashes up for about a second any help plz
ip address
you need to find the ip of ur dm? what image u running?
should be menu> setup> network.. ip addy should be there, also Dreambox control centre can scan for it, or got to your router homepage and look for attached devicesFave replies from various threads
Run an ethernet cable from your box to your router and it will assign you an ip address of 192.168.***.***
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'.Comment
Does your router assign your internal IP addresses via DHCP? I've seen this once before where it assigns an external IP address and then routes that, are you with Virgin for your internet by any chance?My master plan is to live forever..... going to plan so far
