How to maintain a laptop?
  • lyk93
    • 9
    Hi guys I would like to know how to maintain a laptop. Both the software and the hardware.
    For software I know the standard defragment and error checking
  • rg66
    • Dec 2011
    • 133
    My best advice for hardware maintenance is "don't spill coke on the keyboard!"
      A good anti virus avast and somthing like advanced system care run once a week and there both free................
      • Canker_Canison
        • 3905
        Don't use it on your lap, sofa, bed, etc.
        Make sure you only use it on hard surfaces that won't block the cooling vents underneath.
        Canker
        [COLOR=Green]
        • Reapers
          • 242
          maitaining a laptop is not much different from a pc really
          you have your software and hardware to maintain
          like your pc
          heres some little bit of example info.
          Software
          keep upto date on your system updates so less issues and problems for your system.
          defragging your file system and registry
          if you have software for your registry defrag but
          windows has file system defrag with all os.
          some softwares do both.
          registry cleaning
          ccleaner would be your best option for registry
          antivirus,spyware and malware scans
          checking error and security logs on computer/laptop and your router if need be.
          hardware
          keep the comp/laptop clean monitors espically on laptop
          vents on a laptop with compressed air because blocked vents
          cause heat in the laptop
          make sure the laptop is well shut down and not plugged in when cleaning vents.
          keyboard with desktop hoovers
          example
          Play.com - Buy Desktop Henry Hoover online at Play.com and read reviews.
          Free delivery to UK and Europe!
          • MrWho
            • 417
            get a cooling pad.
            Don't worry to much about software you can always re install system ... worry more about backups so you don't lose files ..
            don't drop it ...
            don't spill stuff ....
            And you will be good
            Please click "Thanks" >>>> If I helped you >>>>>
            • johnboy1974
              • 3418
              i maintain my laptop by creating a desktop folder called maintenance. Inside that folder i have malwarebytes free, avg free, eusing registry cleaner, disc clean up and disc defragmenter. I run all of these programs on the first of each month.
              • cablefreejunkie
                • 1717
                malwarebytes a must,,good anti virus,,also got microsoft security essentials running at all times,,as canker says,only use on hard surfaces,,,defrag when it says so and run regular scans,,its a bit like a motor,the better you treat it the longer it lasts
                The control of information is the consolidation of power
                ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
                IF I HELPED HIT THE THANKS BUTTON
                • TomEdwards
                  • Jan 2012
                  • 8
                  Maintenance of a Laptop
                  To all who responded to the msges above - what do think of just using Microsoft Essentials?
                  Tom
                  • braz13
                    • 47
                    I used Essentials for about two years, didn't have any major problems but when I ran SuperantiSpyware it regularly showed up some stuff that Essentials had missed.
                    Now running full Malawarebytes on four computers and all running clean, I still run SuperantiSpyware regularly which always comes up clean other than the odd tracking cookie.
                    • cablefreejunkie
                      • 1717
                      Tom
                      IMHO malwarebytes is a must also forgot to mention super antispyware,i have both and mse plus anti virus
                      better to be safe than sorry
                      • Canker_Canison
                        • 3905
                        Tom
                        Never used it, guess I have some trust issues when it comes to microsoft protecting my computers when most of the problems are caused by poor programming in windows
                        Every system I work on gets malwarebytes (full), avast antivirus &, if it's my own system, comodo firewall.
                        Every piece of protective software that comes with windows is turned off.
                        I've had no serious nasties, exceptions being those packed up with keygens that are easily removed.
                        If you listen to what they tell you, you won't suffer.
                        Canker
                        [COLOR=Green]
                        • luisete123
                          • Feb 2012
                          • 24
                          I have this Targus cooler chili pad, and is one of the best things I bought for my laptop!
                          Cheers
