Hi can anyone tell me how to restore my laptop to factory settings thanks ant
dell laptop
here is a link to give some info on how to
Restoring Your Dell Computer to Original Factory Installation with Dell DataSafe Local Backup 2.0 | Dell
also heres a guide if you need a make any backups for your laptop
Creating a Full System Backup Using Dell DataSafe Local Backup 2.0 - KB Article - 353563 | Dell
hope it helpsLast edited by Reapers; 8 March, 2012, 17:23.Comment
i fixed a newer dell laptop recently for someone and the recovery option was turned off in the system properties meaning it was not showing on F8 startup.
if you find you have no recover option at F8 startup, check startup and recovery options in your system properties and tick the box that says,
"Time to display recovery options when needed = 30"
dell can be sneakyComment
Oh agreed!,, and the older ones can be even harder to get the cntrol f11 to work, but it defo is there, and is a old ghost type recovery.i fixed a newer dell laptop recently for someone and the recovery option was turned off in the system properties meaning it was not showing on F8 startup.
dell can be sneaky
i tend to use one of the later hirens, it lets you see partitions on disk and try to boot from each with the appropriate flags .
but usually even to see the partition under hirens lets you know its there and dont give up!Comment
