Epson Printer Resets
  • eagleflh
    • Apr 2012
    • 6
    I have epson resets if anyone has the newer model resets let me know. also if anyone needs help. thankx
  • smirnoff_rules
    • 8603
    Digital Kaos - Search Results few here
    • wanga
      • Apr 2012
      Epson sx 125
      Hi! Just read your post and feel like I should have read it earlier. I have an Epson sx 125 but its giving me problems with clogging and ink pad error. Please help me! I'm in Kenya.
      • eagleflh
        • Apr 2012
        • 6
        -THIS IS FROM Johnybeast-
        Hey guys,
        It took me ages to source a SX125 waste counter reset program that works, so I thought I would pop it on here.
        I've uploaded it into the download section, but thought I may as well pop it on here with a bit of guide too.
        I've only tested it on XP 32bit, with a UK SX125 printer, so that's what the instructions will be tailored for. By all means try it on other OS's and feel free to post results.
        Reset instructions for SX125:
        • Install printer if not already installed.
        • Download and extract attached file into a folder on your hard drive.
        • Run 'AdjProg.exe' and click 'Accept' on the splash screen then click on 'Select' at the top.
        • From the pull down boxes, select 'Epson Stylus TX121' for 'Model Name' and 'ESP' for 'Destination', click 'OK'.
        • Click 'Particular adjustment mode' then from the '---- Maintenance ----' section, select 'Waste ink pad counter' then click 'OK'.
        • Click 'Check' on the bottom right, this will query the printer and give information of ink shots and so on.
        • Tick the two boxes on the left, 'Main Pad Counter' and 'FL Box Counter', then click 'Initialize'.
        • It should come up with a message abut restarting your printer, do it!
        Job done, carry on printing!
        I recommend getting a waste ink tank for your printer, have a Google for one, the waste ink pipe is easily accessible from a clip in hatch on the back of the printer.
        Hope that helps, if it's useful, don't forget to thank
        J.
        • kuang
          • May 2012
          my epson sx 125 have massenger General Error. What can i do now?
          • targhos
            • May 2012
            this program reseting a chip ?
            • basbouss
              • Jun 2012
              hi dear
              i need help ,i have Epson stylus sx130 , the waste ink pad counter need to be reset
              • engenheiro69
                • Jun 2012
                sx155
                wy cant i print with my sx125?
                • alvarovargas
                  • Jul 2012
                  Hola amigos! estoy desesperado con mi sx125 y necesito ayuda
                    English only in the forums please.
                    • alvarovargas
                      • Jul 2012
                      Sorry! Please I need your help with one sx125 Thanks
                        Alvaro
                        What you need is here under the PC problem section
                        Use google translate etc and we help you, write in Spanish we're too lazy to translate
                        Lo que usted necesita est? aqu? en la secci?n de problemas de PC
                        Use el traductor de google, etc y le ayuda, escribir en espa?ol que es demasiado perezoso para traducir
                        • andy2012
                          • Sep 2012
                          • 4
                          hi can anyone please help me with how to reset the waste ink counter on the epson bx635fwd as i cannot find a reset program for it thanks
                          • PremierD
                            TAMINATOR
                            • Jun 2009
                            • 13236
                            You wont post that again mate will you ...
                            • napista
                              • Sep 2012
                              Hi eagleflh! Great post. I had to fill toners on my own since the service guy who did it earlier disappeared. I would not have done it without your help.
                              Many thanks.
