Windows 7 - Formatted system backup drive D
  • srivihk
    • May 2012
    Mistakenly formatted the D drive partition containing the system restore or backup.
    Will it affect the desktop machine.
  • ray156
    • 669
    your pc should be ok,will still run your O/S
    but if anything goes wrong with windows 7,it could be a bit of a problem,as you deleted your backup partition,which is used to repair your copy of windows,should any problems occur,but all is not lost,if you got a backup disk with system fine,you can use that,if not you can download a backup disk,
    or boot disks.or if machine was new,you can order a backup disc from manufacturer.
    • Masterzad
      • Jun 2012
      • 10
      Backing up important data to an external disk is alot better than using a recovery partition. So don't worry about the recovery partition just backup your data
        You mean dont worry about it untill you need to do a factory default and you cant because you deleted it.So backing up his data to another hdd wont help......................
        • Masterzad
          • Jun 2012
          • 10
          Well you can put in a windows 7 DVD and reinstall.
          Might be longer but it's what i do.
