Can I use a Sata disk as the master and an IDE as a slave?
I'm going to be upgrading my dads PC which is all IDE and it's all new Sata stuff. New sata hdd with new window install, can I add the old IDE drive in as a slave so that he doesn't loose all his old stuff?
Is it a case of leaving the IDE disk out while you install the new one, then once you're all up and running, se the IDE as a slave and then add it in?
Cheers!
Cheers!
