Help Streaming ADMC Sports....
So got in on JSC currently streaming on HD6 pic on my samsung32 is clear as ,no stutter though actual quality looks more SD ...its streaming at 330K to 640K mostly around 605K...im using ie on win8 and have upped the B_Stream priority using cfosspeed..this is over smartdns europe........Just trying diff feeds on Catch up all seem SD quality im also streaming NOWTV cricket, quality is better but cant gauge until a live stream to be sureLast edited by sols; 5 August, 2013, 14:04.Comment
Aljazeera Sports 2013/2014 Premiership Football WatchJSC.com - YouTube
There is an idea of the quality...Comment
If the football stream is as good as that it'll do for me.Aljazeera Sports 2013/2014 Premiership Football WatchJSC.com - YouTube
Had the same problem myself, found a way around it as follows; As per the Adam's jsc guide connect to the Egypt VPN and start the sign up process. When you get to the PayPal sign in page disconnect the VPN and sign in as normal. Once you are in your PayPal account reconnect the VPN and complete the payment.Just trying to sign up when redirecting to Paypal i get Return to merchant and try a different payment method
so im guessing that its down to logging into paypal via the vpn but if i disconnect the vpn will i then lose the egypt ip...?????
Damn ....
Anyone tried signing up with a cc..???
My paypal account was blocked which what was causing the error
This method worked for me and I was able to set up an account, hope it helps.Comment
My paypal account was blocked so i believe that was the cause but i bought a sub for JSC from a user on here but if you had the same issue great for posting if anyone else gets the issueHad the same problem myself, found a way around it as follows; As per the Adam's jsc guide connect to the Egypt VPN and start the sign up process. When you get to the PayPal sign in page disconnect the VPN and sign in as normal. Once you are in your PayPal account reconnect the VPN and complete the payment.
Mine hasn`t upgraded either...that`s clearly because where i live, there`s no AJS live app in play store->no updates.
How could i get the latest version of AlJazeera live app to my android phone? Pls someone help...Comment
