hi peeps my puter will not boot only in safe mode ran scan with avast Win32:Alureon-DA [Rtk] + loads more any help will be thanked
~~~~ed
Tags: None
also run superantispyware, you can get free version here SUPERAntiSpyware.com - AntiAdware. AntiSpyware. AntiMalware.
Alureon removal tool here AntiSpyware - Remove Alureon
also try a rootkit remover like Unhackme, have a read here Rootkit Removal GuideComment
it might not be a software issue
schedule a disk check for next start up, you can do this by right clicking on the hdd, select properties then tools. select check disk and check the 2 boxes, it will ask if you want to schedule for the nest start up, select yes and restart.Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable
screw you nag3
