~~~~ed
  • mtv1
    The Stig PT
    • 4413
    ~~~~ed
    hi peeps my puter will not boot only in safe mode ran scan with avast Win32:Alureon-DA [Rtk] + loads more any help will be thanked
    u tried malwarebytes yet ? if not try it but update it as well before u use it, and keep off them dodgy ~~~~ sites.
    • cunny
      • 4915
      You will need to schedule a scan before the pc loads, so load into safe mode, scheule 1 from avast, reboot an it should run.
      You prob cant delete them due to them being used in some form.
      • smoggy
        • Apr 2009
        • 12775
        also run superantispyware, you can get free version here SUPERAntiSpyware.com - AntiAdware. AntiSpyware. AntiMalware.
        Alureon removal tool here AntiSpyware - Remove Alureon
        also try a rootkit remover like Unhackme, have a read here Rootkit Removal Guide
        • dctyper
          • 2539
          it might not be a software issue
          schedule a disk check for next start up, you can do this by right clicking on the hdd, select properties then tools. select check disk and check the 2 boxes, it will ask if you want to schedule for the nest start up, select yes and restart.
          Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
          previous life dm800hd and 500c on cable screw you nag3
