ASUS F3H Series
  • kingy17
    • Aug 2009
    • 67
    ASUS F3H Series
    Hi my dad has a ASUS F3H Series laptop which the motherboard is knackered. where can i get another motherboard to replace it with to get it working again
    cheers
  • nano_watt
    • 21
    If you are looking to learn then I would get another MB from ebay, else I would not bother you will wreck the casing whilst installing and the processor is normally soldered in and you will do it untold damage unsoldering it.
    Its a no brainer m8 sell your old laptop on ebay and get some money back for the parts still working.
    • ruudvandan
      • 1091
      although I've never replaced a motherboard in a laptop i have completely stripped one down and repaired the motherboard. one piece of advice i would give if you are changin the motherboard, mark the screw holes on the old one with a marker so you can easily find them when screwing the new board in, they're hard to find otherwise!
      http://www.facebook.com/BoycottFIFASponsors
      • kingy17
        • Aug 2009
        • 67
        I have been looking for a replacement motherboard but nothing it coming up on ebay besides other parts on ebay.
        Can i find out the name of the motherboard?
        We are guessing the motherboard has blown
        • caveman_nige
          • Feb 2008
          • 4920
          If you undo some of the screws to some of access areas of the bottom (ram cover or wifi card cover for example) you should see a part number sticker on the mainboard somewhere..
          what is the actual model number of the laptop as it is printed on the bottom of the laptop?
          • kingy17
            • Aug 2009
            • 67
            Model - F3H
            MB Ver - F3H ID:1A
            72N0AS089991
            F3H-AP003C
            Check Number:6057
            This is was it says EXACTLY on the label
            • kingy17
              • Aug 2009
              • 67
              any ideas?
              • caveman_nige
                • Feb 2008
                • 4920
                well there is little or no info on that machine...
                ASUS may help tel: +44-870-120-8340 (09:00-17:00 Mon.~Fri.)
                They will want your serial number etc http://support.asus.com/repair/repai...Language=en-us
                They will give you a scarey price, but make sure you make a note of the part number of the replacement mainboard so that you can compare prices with other suppliers.
                A good place to get laptops fixed is 'clonesuk' you will have to google them, but they are able to fix mainboards to component level a lot of the time and do hold a lot of spares... no guarantees, just an option before you sell it for scrap...
