How to clone SSD?
  • gttuning
    • Dec 2012
    • 3781
    How to clone SSD?
    Hi all whats the easiest way clone 512SSD to 2T SSD ..
    Sent from my SM-G965F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  • qwojtus
    • 451
    You can use Aomei Backuper or Easeus Partition. Quite easy I think.
    freeware
    • ScottyP60529
      • Dec 2022
      I used Macrium Reflect, it is excellent.
      • kapadokya
        • Jun 2022
        • 118
        best app for me
        Time does not change anything
        • serpents
          • Feb 2022
          At first make sure that HDD is not filled above 500GB. Delete anything not wanted to make disk use below 500 GB plus overhead for data moving.... let say make 600 GB free. Then connect SSD to system, boot from some recovery drive with disk cloning software and clone HDD to SSD. After cloning replace HDD with cloned SSD and you are good. Particularly in last year for me Lazesoft Disk Image & Clone on Hirens BootCD PE on USB stick did the trick without any issues.
          • reinholdjj
            • Sep 2024
            • 6
            i always use:
            minitool partition wizard
            Clonezilla
            Minitool also have a usb version, so you can boot directly from the usb.
            • acuraracingvtec
              • Dec 2024
              • 31
              Buy a samsung ssd and go to the website they have their own cloning software when you use their ssd.
              • Mark89
                • Jan 2025
                • 5
                Download clonezilla and create a bootable usb with Rufus.
                Connect both SSD so the same computer.
                If it is a laptop, maybe you need a usb to sata or usb to nvme cable.
                See documentation on
                Clonezilla, a free and open source software for disk/partition imaging and cloning.
