At first make sure that HDD is not filled above 500GB. Delete anything not wanted to make disk use below 500 GB plus overhead for data moving.... let say make 600 GB free. Then connect SSD to system, boot from some recovery drive with disk cloning software and clone HDD to SSD. After cloning replace HDD with cloned SSD and you are good. Particularly in last year for me Lazesoft Disk Image & Clone on Hirens BootCD PE on USB stick did the trick without any issues.
