FREE Dell Laptop password removal
jumper doesn't work on these
providing you have posted your tag in the correct case and inputting the password in correct case the password should work
Eiz9gyr6FKkq73sw upper case in redComment
DELL INSPIRON 2650 - BIOS PASSWORD
Hello Friends, please can you help with password to DELL INSPIRON 2650 Laptop?
I can acces to OS, but i can not modify parameters in bios, it ask me for password, i buy it with this problem.
I'm not sure about what code you need, so here i public 2 pics from TAG 9H9ZJ0J and ID from this laptop.
Thanks in advance for your help.
RegardsComment
Incorrect Pass
Hello my friend, Thanks for your help, but it says password incorrect.
Maybe the problem to generate the correct pass is the before last char "O" or "0" in Tag, i think is zero... Or what can i do?
Hope you can help me to know the Master bios password from this laptop.
Here the Service Number in a cap.
Thanks again.Attached FilesLast edited by sca.net; 20 September, 2011, 15:54.Comment
sca.net
it looks to me a zero
the one I gave was for tag ending -595B
if its -D35B then gunz0dmp (5th is a Zero)
if its -2A7B then password would be rMLB0D15oACay4io (5th is a zero 9th and last are o for orange) also note the the case changes
make sure you type them in the correct caseComment
Hello smoggy...sca.net
Sorry to be a pain, but it still says incorrect password and i get "System Disabled [15328]" at 3th try.
I try in different ways with those passwords you gave me but no succes.
I dont find any of -595B,-D35B,-2A7B endings in any place in this laptop... The Only Service TAG endings i find is "ZJ0J" from "9H9ZJ0J". And Express Service Code is: 206-357-401-63.
I've disassemble it before but didn't find the battery and also found no reset pin. what a problem i have....
Any suggestions?
Thanks.Comment
the service tags are 11 characters and generally end in one of those three numbers although it doesn't always show them.
only other thing I can suggest is to try a plug in qwerty type keyboard just in case one of the keys is not working correctly or your keyboard isn't set up as english qwertyComment
Nothing my friend, i have try with Caps lock for E FK ,
incorrect password
the service tag is correctComment
