sca.net
it looks to me a zero
the one I gave was for tag ending -595B
if its -D35B then gunz0dmp (5th is a Zero)
if its -2A7B then password would be rMLB0D15oACay4io (5th is a zero 9th and last are o for orange) also note the the case changes
make sure you type them in the correct case
FREE Dell Laptop password removal
Incorrect Pass
Hello my friend, Thanks for your help, but it says password incorrect.
Maybe the problem to generate the correct pass is the before last char "O" or "0" in Tag, i think is zero... Or what can i do?
Hope you can help me to know the Master bios password from this laptop.
Here the Service Number in a cap.
Thanks again.Attached FilesLast edited by sca.net; 20 September, 2011, 15:54.Leave a comment:
DELL INSPIRON 2650 - BIOS PASSWORD
Hello Friends, please can you help with password to DELL INSPIRON 2650 Laptop?
I can acces to OS, but i can not modify parameters in bios, it ask me for password, i buy it with this problem.
I'm not sure about what code you need, so here i public 2 pics from TAG 9H9ZJ0J and ID from this laptop.
Thanks in advance for your help.
RegardsLeave a comment:
jumper doesn't work on these
providing you have posted your tag in the correct case and inputting the password in correct case the password should work
Eiz9gyr6FKkq73sw upper case in redLeave a comment:
With microsoft usb keyboard, same problem... incorrect password
what can possible?
some days ago i have try to close the cmos jumper ...but im not lucky
Leave a comment:
Hi guys, i have the same problem with my dell
DELL E6410 Service tag : 66972ZN1-2A7B
anyone can help me ?Last edited by Lordformat; 17 September, 2011, 13:34.Leave a comment:
I need to bypass the admin password on my dell latitude d630
My service tage is JTBW33J-595B
Hope someone can help. It would help me alot
VFXFMLeave a comment:
Hi !When the white screen saying "This system is protected by the Password Authentication System blah blah blah"... what is the full code it gives you? Please keep in mind it's case sensitive!
For instance, does the white screen say: 58cdc3j-595B? or 58CDC3J-595B? Or something different? We need to know this in order to give you the password.
Thanks!
how about this one #DKCXX3J-595B
Any help would be greatly appreciated. Thanks in advance!Leave a comment:
Leave a comment:
