cant connect
  • 13rooey
    cant connect
    Hi all got a prob with laptopwhen not at home get wierless connection but cant connect to internet any ideas? using an aspire 7540! HOOPe someone can help!
  • chroma
    • 1976
    Do you have access to the wifi network your trying to connect to? as in the password?
    He who laughs last thinks slowest.
    • Reapers
      • 242
      routers. just some info
      make sure firmware is up to date
      so less chance of software problems.
      check to see if you can connect to the router
      with your router security algorithm password wpa2,wpa etc
      also make sure your hardware your using for the network can read the security like wpa2,wpa etc
      sometimes that causes issues but its less likely now with hardware.
      check to see if your internet is actually connected to the router its usually
      under status or somethink like that.
      check your wireless part is enabled and broadcast is on so laptop can see it.if you
      have types of security or schedules on eg. a mac address filter on youll need to add
      your ip address of the laptop to the filter to allow only them ip addresses.
      also if you have a dhcp check to see you have room for your laptop
      and set the number of computers in your network as the maximum.
      good luck with it
      • msmikey724
        • Oct 2010
        • 17
        Check to see if you can connect to the router.
        Make sure you have enterd the correct security password for the router to connect to your laptop.( the passsword should be on the router).
        • 13rooey
          Thanks all!! Will try again at the weekend but have tried several times in the past (at various different places) using WEP key and it's always shown same problem - Connected but no Internet Access.
          Anyone seen this issue before??
          Cheers.
          • letoncha
            • Oct 2010
            Maybe you have static ip address configured on your lappy. When you connect to a random router (with correct password of course), it is probably that has DHCP enabled. Try enable DHCP on your lappy and connect to a wireless network again.
            • termiantor
              • 400
              download norton removal tool problem solved mate
              HAD THE PARTY LOL
