router signal problem wimax
  • kuwaiti
    • Feb 2011
    • 110
    hi i got new Wimax router but in my house low signal
    if i put it outside on the window edge i get nice signal , but cant leave it out
    any chance to get signal from outside to indoor like the Huawei antenna ?
    my device got NO antena port its built in
    WiMAX Indoor Modems
    i really need help inside i get 240 download rate if its outside i get 1 mb
  • cactikid
    • 12017
    have you tried it in various parts in house and turning it may also improve it,mine packed up after 4 months went dead.
    • kuwaiti
      • Feb 2011
      • 110
      Oh ya i did same thing
      U cant belive it if only i open the window and put it at the edge i get X4
      I guess i cant do much if it got no port for antenna
      • cactikid
        • 12017
        sometimes rebooting it may clear any issues.as in off for 5 mins or so.
        • Canker_Canison
          • May 2010
          • 3905
          It's a bit overkill, but you could bounce the signal with a parabolic dish.
          But the thought of a 1m dish taped to the side of your router may not go with your decor
          Canker
          [COLOR=Green]
          • kuwaiti
            • Feb 2011
            • 110
            Cactikid really thanks but its signal thing even mobile signal in my flat not that good . Old building got hard work into it if u know what i mean
            • kuwaiti
              • Feb 2011
              • 110
              Canker i will instal a 8f dish if i have to but how do i get the signal to a router that got no antenna port
              • Canker_Canison
                • May 2010
                • 3905
                Have a read of this. You don't need to understand it all, the pic on page 3 is the most useful.
                Take a parabolic dish & remove the LMB from the end of the arm.
                Find out where the antenna sits inside the router
                Try to get the router lined up at the end of the arm so the antenna will be in the focal point of the dish.
                Then aim the dish where you want to use the internet
                Canker
                [COLOR=Green]
                • kuwaiti
                  • Feb 2011
                  • 110
                  to be honest thought ur kidding first
                  so u get dish like the one for sat channels ? should i instal LNB ? and face it to there the tower is then put the end of the wire inside my wimax router??
                  im looking for anything to bring signal and make it stronger inside but how to make my router get the signal without any input for antenna is hard
                  • kuwaiti
                    • Feb 2011
                    • 110
                    inside wimax antenna
                    ok check the inside ?
                    any external antenna for that small plugin ?
                    • Canker_Canison
                      • May 2010
                      • 3905
                      Originally I was joking. Why anyone would tape their router to the end of a dish is beyond me.
                      But those are big antennas in that unit.
                      My first option would be to remove them from the inside & fit them externally
                      The second choice would be to source two male connectors to fit the board & two external high gain antennas.
                      Cut the connetors off the new antennas & solder the wires to the new male connectors. Plug them in & see what happens.
                      Or you can make an adapter so you can have an external connector. That way you won't need to cut the connectors off the new antennas.
                      Have a read through of this. If you were to try & upscale the design to fit the antennas once you have them outside the case, it might be a lot easier & cheaper than the other options.
                      Canker
                      [COLOR=Green]
                      • kuwaiti
                        • Feb 2011
                        • 110
                        my friend took the built in antenna out and the antenna melted :P
                        its 52c
                        • kuwaiti
                          • Feb 2011
                          • 110
                          could i make this work ?
                          10DBI Wireless WiMax WiFi Panel Antenna 5m Cable RP-SMA | eBay
                          i could replace the end of cable to fit the input inside my router BUT will it work ? wont it need power from same cable
                          • Canker_Canison
                            • May 2010
                            • 3905
                            Not sure how well that would work. The problem being that your router has two antennas. Where the antenna model you're looking at has a single connector.
                            How did you manage to melt the antenna?
                            You don't need any extra power for antennas, they have a tiny amount supplied via the main board. All the antenna does is pick up & send out the signals. The router has amplifiers on the board to boost what is picked up or being sent out.
                            Another thing to remember, for ever meter of cable between the router & antenna you lose in signal gain. Keep the wire between the two as short as you can (without making it so short it causes problems), you should really be looking at 1m-2m max.
                            Canker
                            [COLOR=Green]
                            • kuwaiti
                              • Feb 2011
                              • 110
                              Ok thanks can , thanks all
