old pc boot manager gone
  • mtv1
    The Stig PT
    • 4413
    my sisters pc is saying boot manager not found , hard drive is wiped too tried installing win 7 and linux wont load says boot manager not found tried repair on win7 no good , its an old machine pentium4 told her to bin it but cash is a bit tight any fix ??
  • cunny
    • 4915
    Ok couple of things to try.
    1st of is boot sequence in bios.
    2nd hdd priority in bios
    3rd if your doing a full format, then i would set boot priority to 1st cd/dvd and select correct drive. You also want to delete all partitions on the hdd.
    Ensure hdd is seen in bios.
    Boot into setup of windows/linux and check its seen again, format it and let it instal. If you get the same error once rebooted, its your boot sequence.
    TBH i would be thinking of installing windows xp on a P4 setup.
    Run repair console from xp cd and use command fixmbr to repair master boot record
    • mtv1
      The Stig PT
      • 4413
      THANK YOU CUNNY YOU ARE GREAT
      • cunny
        • 4915
        Thanks Stig
