Laptop won't turn on
  • stew86
    • Nov 2010
    • 236
    Hello I plug my charger into my advent 7113 the light starts flashing to say it charging (the battery is ~~~~ed) I push the power button to turn it on and it goes dead the charger light stops flashing and laptop won't turn on. Any help please
  • Elric
    V.I.P. soft lad
    • 853
    have you tried takin the battery out then plug in the charger
    • Bazigar007
      • Feb 2011
      • 74
      Sounds like Either Cpu down or harddrive down. Pc boot up is when both these are working.
      • kianniamh
        • Mar 2010
        • 182
        Had a similar problem myself, mine was the ram had come loose, took the bottom off the laptop and reseated the ram and it sorted it, could be a totally different prob though.
        • SeanScotland
          • Aug 2011
          • 4
          Also, if the Laptop has 2 sticks of ram, remove one & try them one at a time. Twice now I've had a laptop have 1 stick go bad, & those were the symptoms.
          Good luck.
          • stew86
            • Nov 2010
            • 236
            Thanks for the message I have checked the ram tuck the battery out still no joy
            • Canker_Canison
              • 3904
              Try reseating the heatsink on the processor.
              Had a problem with a laptop when I tried to instal windows 7. It would get so far then just shut off. It's not quite the same problem but an easy fix.
              Canker
              [COLOR=Green]
              • jazzipup
                • 14
                Common fault on these i'm afraid. It's the gpu on the board that's overheated. I've still got one upstairs
                Possibly an xbox type issue where the gpu processor comes away from the board, as it gets to hot, the board warps and comes away. you'd probably have to remove the board and try the oven trick, that aside maybe treat yourself to a new I5 lappy
                • luis12
                  • 907
                  Lap not on
                  Hi mate, you hear a harddrive?. Had you check for a backlite not turning on, it makes a dark screen and likes a not funtional Lapt.
