Hello I plug my charger into my advent 7113 the light starts flashing to say it charging (the battery is ~~~~ed) I push the power button to turn it on and it goes dead the charger light stops flashing and laptop won't turn on. Any help please
Laptop won't turn on
Also, if the Laptop has 2 sticks of ram, remove one & try them one at a time. Twice now I've had a laptop have 1 stick go bad, & those were the symptoms.
Good luck.Comment
Try reseating the heatsink on the processor.
Had a problem with a laptop when I tried to instal windows 7. It would get so far then just shut off. It's not quite the same problem but an easy fix.Canker
- The Baby Eating Bishop of Bath & Wells[COLOR=Green]Comment
Common fault on these i'm afraid. It's the gpu on the board that's overheated. I've still got one upstairs
Possibly an xbox type issue where the gpu processor comes away from the board, as it gets to hot, the board warps and comes away. you'd probably have to remove the board and try the oven trick, that aside maybe treat yourself to a new I5 lappy
