hi guys got a problem, just replaced my ink cartridges in my epson r200 printer and the ink light wont stop flashing. It knows the cartridges arent the proper ones, is there any way round this other than buying the proper ones
Flashing ink light on printer
have you used non epson ink with it before??
you have a couple of options use a chip resetter
try uninstall and reinstall printer again
some inks have different versions i had a R265 and had to wait for the correct compatible ink to come out
then i got a r285 the older ink cartridge would not work anymore the chipset was slightly different
you could always take them back to the shop you bought and tell them your printer will not accept them they may give you a set with a newer chipset -
I get this with my Epson R300 and find going through loads of cartridges sometimes though they are 10 a penny.
Another thing it could be is everytime you clean your printer it uses excess ink that fills in a sponge and the printer might need resetting as this used to stop the ink from overflowing.
I had this problem once and used software to reset the clocker on it.
Epson R200, R210, R300, R310 Waste Ink Counter Pad Reset | Tricks-Collections.Com
Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
make really sure u have pushed them down all the way m8 and look for a ciss system for it
CISS Continuous ink cartridge for epson R200 R220 R300 | eBayany information provided is for educational/experimental purposes only.Comment
Have read the chipsetter is the best option and can be picked up cheaply off Ebay.
What you will need to do is try and soak up some of the excess waste ink or at some time you will get an overspill problem thats why they have a counter.
Glad you got it sorted mate.
