Is it my PSU causing this
  • tshirtman
    • 1345
    for a while now my PC freezes occationally and needs a reboot, then sometimes it can take a couple of attempts to reboot, also I sometimes could hear a clicking noise coming from pc when nothing was running.
    then last night. after playing a game I closed the game down and the screen went black, I turned the monitor off then back on, my desktop appears for a mili-second then screen goes black again, I tried a different monitor and same again,
    I turned pc off, when I turned it back on it wont reboot, I cant even get in to the bios, it trys to reboot but stops after a second or two, I'm thinking PSU or could it be motherboard or graphics card,
    any sugestions would be appreciated.
    !retupmoc eht ni deppart m'I !pleH
  • cunny
    • 4915
    Check for loose connections. The only moving parts inside a pc are heat sink fans and hard drives. So check them for the noise.
    I'd be tempted to keep an eye on tempratures of stuff like cpu ect.
    • tshirtman
      • 1345
      cheers m8, the clicking noise is like the noise you hear when it's booting up,
      and I cant check anything , as I cant get it to boot, somebody sugested resetting the bios to default, is that just a case of taking out the cmos battery out for a while.
      • cunny
        • 4915
        Yes. Take the battery out and leave it out for a while. Also unplug any dvd drives usb devices except keyboard mouse.
        I could be wrong but I think its going to be a hard drive making the clicking.
        When you press the power on does anythin at all happen? Like fans begin to spin then stop?
        • tshirtman
          • 1345
          When i boot it, I can hear the hard drive start, there's a few clicks, all the fans are going (psu, cpu, vga), but then it just hangs, it doesn't even get to asus screen, and as said earlier I cant get into bios.
          • cunny
            • 4915
            Have u disconnected everythin? Also disconnect hard drive(s)
            • tshirtman
              • 1345
              I stripped it down today, then tried all the hardware one by one, but found nothing,
              so I took the PSU out and opened it up, there was fluid all over it, about 3 capacitors had blown,
              went and got a new 750w unit, I thought great problem solved, then I plugged monitor in and it was dead, I think the dodgy PSU has fried it, luckily it is still in warranty, so I'm waiting for a RMA from Benq, just hope they agree to repair/replace it, thanx for the input m8.
              • Sarann
                • Oct 2011
                • 12
                It looks as though you might have it sorted, but it sounded like Hard drive packing up to me
