Removed cd drive, now pc not working!!
  • mickydibble
    • 2166
    I removed a broken unworking cd writer from pc now the comp is not booting, can't find IDE drives etc .. Thought I would just be able to take out and maybe change the slave/ master about but no can't get it to work, it did boot at first but with the display really large, I swapped stuff about an now won't boot at all!!!.
    Should I have uninstalled the drive on pc first?, what shall I do now? Should I try put back as it was? Cheers micky
  • tedjini
    sur le bios
    • mickydibble
      • 2166
      ? Don't understand sorry , but can't get into bios
        may sound daft m8 but if it will not boot at all just check your connections,you may have loosened something when you removed the drive
        • mickydibble
          • 2166
          Ok m8 will check all connections. Cheers
          • azzahra
            • Oct 2011
            • 139
            any info about your problem mickydibble...??? or solved
            • Reapers
              • 242
              like gc1966 suggested it should fix it once you
              reassemble it
              also check your psu and ram.
              what did you change hardware wise?
              the problem with your display happens quite a lot can be a number of reasons for that problem with displays
              like when unistalling software or games that change the resoultion.
              could be that :
              your graphics driver needs reinstalling
              the resoultion or dpi needs changing back to normal
              • mickydibble
                • 2166
                Just won't boot, loads screen but does not boot from cd now, think that's because I have took the drive cd out. but there is still one in, it was just that the one I removed wouldnt work or burn discs.but the disc I removed was the one my pc used to boot from disc? It's just sat here now and me looking at it all confused
                • Grizz
                  • 1598
                  try pressing press F1 or F2 or DEL or ESC or F10 to get into bios, see does the bios recognise the drive.
                  what kind of pc is it?
                  • Puffingweed
                    • 35
                    When you took out the Cd drive was there any other devices connected on the ide cable? I only ask as you may have dislodge the cable connecting the hard disk?
                    Also
                    what is the exact error messege you get on your screen when you switch on?
                    • mickydibble
                      • 2166
                      The IDE cable was connected to my other cd drive,
                      • andiewill
                        • 490
                        Try getting into the BIOS settings and change the boot sequence, if you say the computer used to boot from the drive you took out, that must have been the drive for your boot start up, now it can't find it so as stated you need to change the boot sequence i belive in the BIOS settings.
                        or just another thought use the cable that was connected to the one you took out and plug into the working drive to see if that fixes it.......
                        ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
                        • saad2001
                          • Nov 2011
                          You have to change settings in the bios
                          • cunny
                            • 4915
                            There should be 2 ide channels and a floppy channel on the motherboard.
                            What other devices are connected to the IDE lead(s) and at what jumper settings? master/slave
                            • mickydibble
                              • 2166
                              I will try these suggestions when at pc and get back Cheers Micky
