COMPUTER KEEPS GOING OFF
  • femmym
    • Aug 2009
    • 163
    why does my PC keep switching its self off every time i try to use it sometimes i don't get as far as windows screen i only get as far as far the boot up screen any help i would be very grateful thank you . femmym
  • Bann32
    • Oct 2011
    • 518
    Take side off case and clean the fans it could be overheating, then try booting with side off.
    If your still having problems, then there are a few things it could be.
    • femmym
      • Aug 2009
      • 163
      il give that a try
      • johnnycboy
        • Aug 2011
        • 38
        Dodgy lithium battery a possibility - how old is the PC?
        • Canker_Canison
          • 3905
          Just had similar issues with my dopey brothers PC. Got to the point where it wouldn't do anything past the post screen.
          Turned out to be the hard drive.
          Here's a brief list of possibilities....
          Overheating (already mentioned)
          Bios battery (already mentioned)
          Dead/failing HDD
          Bad sectors on HDD
          Corrupted system files
          Virus
          Memory module
          PSU
          CPU
          Gfx card
          Canker
          [COLOR=Green]
          • R_J
            • 492
            I have see weak power supplies do this, try disconecting the hard drive and see if it stays on longer. if the power supply is weak the additional current draw of the hard drive booting will be enough to shut down the power supply.
            • R_J
              • 492
              When the drive is booting the extra current draw could shut down a weak power supply.
              • obdrs
                • May 2011
                • 8
                Probably damaged GPU
                • R_J
                  • 492
                  So did you get it repaired? What was it?
