USB not recognised
  • davecabezo
    USB not recognised
    I seem to have lost connectivity to 2 of my USB ports. I'm running XP Pro. I've looked in control panel/Device manager but there aren't any yellow question marks against any of the USB controllers.
    Any Ideas,
    Dave
  • garethr
    • 16
    Is it the front ports or the rear ports?
    If its the front ports, these have a tendancy to break. If you know anough about computers to remove the side of the case give this a go:
    !!! MAKE SURE THE POWER IS DISCONNECTED BEFORE DOING THIS!!!!
    Open the case and track down where the rear of your USB ports are. there should be a cable running from these (sometimes there are a few cables, some are for the power button and LED etc if they are close to the ports).
    It should trace back to your motherboard and should plug into a section labeled USB1 or FRONT USB or something similar.
    Make sure these are plugged in properly and havent fallen out.
    Let us know how you get on.
    • davecabezo
      Cheers,
      I will try tomorrow and report back.
      Regards,
      Dave
      • koihai
        • May 2012
        Any update on this dave as my ports are not working either.
        • jatinpatel8782
          • May 2012
          you need to replace south bridge ic for repaired usb port
          • Chewie
            • May 2012
            I think that would be a little drastic if the OP has only lost 2 of his ports.
            If the failing ones are on the front/top of the case and they are plugged in to the motherboard, there's a few possibilities...
            - as mentioned, cable to ports has come unplugged from motherboard
            - cable-motherboard is not one plug, but 9 single connectors and they are in the wrong order
            - cable to ports had been damaged somehow
            - bad soldering where they mount to their board. Front off, remove a couple of screws and the connecting cable, carefully re-solder. Replacement is reversal of removal.
            My guess is the solder... seen a couple of these in the past where sticks or plugs get kicked, snagged or generally yanked.
