group manager error
  • jckw
    • 760
    group manager error
    hi all i have a problem with a error it says goup manager has a fault and will have to close, when i try to load nero, power dvd ,or even keymaster, i think its related to net framework but i dont know were or how to uninstall it or were it is on pc ive tried loading it again and it just fails any help please.
    we are all learning each day
  • jckw
    • 760
    can i reset system other than format or system restore
    • caveman_nige
      • Feb 2008
      • 4920
      you can system restore or you can remove .net in 'add or remove programs' in the control panel... You will find a bunch of .net things to remove.. However you may wish to you the following tool first as it could save you a lot of hassle...
      Aaron Stebner's WebLog : .NET Framework Cleanup Tool User's Guide
      You can then re-install .net with a clean version
      • jckw
        • 760
        Originally posted by caveman_nige
        you can system restore or you can remove .net in 'add or remove programs' in the control panel... You will find a bunch of .net things to remove.. However you may wish to you the following tool first as it could dave you a lot of hassle...
        thasnks my m8 i only just seen this ill give it a go and report back
        • jckw
          • 760
          wot a man unistalled it cleaned it re installed sorted thanks very much m8
          • jckw
            • 760
            thanks again cave-man just the job
            • jckw
              • 760
              ive used cleanup tool and installed new netframework now i cant shut pc down ie start turn off i have to close netframework down in task manager then it shuts down but wont reboot for 10 mins any ideas all programes are working fine but can't turn the thing off
              • jckw
                • 760
                caveman nige any ideas m8
                • caveman_nige
                  • Feb 2008
                  • 4920
                  Well you could try a barrage of registry cleaning tools or you could try system restore.. To be honest mate, as you have been at this for a week its probably best to start looking at a system restore root.
                  Personally, if it was mine, i would run something like ccleaner through and then if that did not work I would do a system restore. For me its time issue....
                  • jckw
                    • 760
                    i know but the system if all working a1 now just wont let me shut down i wonder if ive installed it in the wrong directory or something
                      system restore m8 take it back to just before u had the prob,all ways works for me when i fcuk something up im surprised u havent
                      tried it all ready
                      • caveman_nige
                        • Feb 2008
                        • 4920
                        try the ccleaner and also nt registry optimizer, see what happens..
                        CCleaner - Download
                        Registry cleaning and optimizing (REGCLEAN.EXE and NT Registry Optimizer).
                        You have nothing to loose, but something may be learned.. Let us know what happens..
