hi all i have a problem with a error it says goup manager has a fault and will have to close, when i try to load nero, power dvd ,or even keymaster, i think its related to net framework but i dont know were or how to uninstall it or were it is on pc ive tried loading it again and it just fails any help please.
group manager error
can i reset system other than format or system restorehi all i have a problem with a error it says goup manager has a fault and will have to close, when i try to load nero, power dvd ,or even keymaster, i think its related to net framework but i dont know were or how to uninstall it or were it is on pc ive tried loading it again and it just fails any help please.we are all learning each day -
you can system restore or you can remove .net in 'add or remove programs' in the control panel... You will find a bunch of .net things to remove.. However you may wish to you the following tool first as it could save you a lot of hassle...
Aaron Stebner's WebLog : .NET Framework Cleanup Tool User's Guide
You can then re-install .net with a clean versionComment
thasnks my m8 i only just seen this ill give it a go and report backyou can system restore or you can remove .net in 'add or remove programs' in the control panel... You will find a bunch of .net things to remove.. However you may wish to you the following tool first as it could dave you a lot of hassle...
You can then re-install .net with a clean versionwe are all learning each dayComment
thanks again cave-man just the jobyou can system restore or you can remove .net in 'add or remove programs' in the control panel... You will find a bunch of .net things to remove.. However you may wish to you the following tool first as it could save you a lot of hassle...
ive used cleanup tool and installed new netframework now i cant shut pc down ie start turn off i have to close netframework down in task manager then it shuts down but wont reboot for 10 mins any ideas all programes are working fine but can't turn the thing offwe are all learning each dayComment
caveman nige any ideas m8we are all learning each dayComment
Well you could try a barrage of registry cleaning tools or you could try system restore.. To be honest mate, as you have been at this for a week its probably best to start looking at a system restore root.
Personally, if it was mine, i would run something like ccleaner through and then if that did not work I would do a system restore. For me its time issue....Comment
i know but the system if all working a1 now just wont let me shut down i wonder if ive installed it in the wrong directory or somethingWell you could try a barrage of registry cleaning tools or you could try system restore.. To be honest mate, as you have been at this for a week its probably best to start looking at a system restore root.
Personally, if it was mine, i would run something like ccleaner through and then if that did not work I would do a system restore. For me its time issue....we are all learning each dayComment
gmb45
try the ccleaner and also nt registry optimizer, see what happens..
CCleaner - Download
Registry cleaning and optimizing (REGCLEAN.EXE and NT Registry Optimizer).
You have nothing to loose, but something may be learned.. Let us know what happens..Comment
