What is the best free tool for a slow computer?Cheers.James.
slow computer
install this Download CCleaner 3.21.1767 - FileHippo.com
run the cleaner & the registry cleaner and should de-clutter ur system making it run abit smother
other than that tell us ur spec : ram cpu motherboard gfx
andwe can tell u what can be ugraded to make ur computer run faster
is it a pc or a laptop? -
this program will tell u every detail about ur system
in here u will find the make and model of ur board under HARDWARE motherboard
also under HARDWARE will be memory. this is ur ram and will tell u how much u have installed and how much more u can install (full capacity)Attached FilesLast edited by Cod3waX; 26 July, 2012, 19:49.Comment
Hi there
You can also download a software called speccy this will tell you inside and out on your current computer systemComment
type msconfig into search go to startup disable all then services you will see tick disable all microsoft tic it reboot your machine will run 30-40 % faster also use cccleaner once a month and avast do a boot scan every monthComment
Check how much HDD space is free on your pc, you could do with at least a third spare. Your RAM of 760mb does not seem a lot. If you go to crucial.com and run the scan they will tell you what type of RAM your pc has currently and what it can be upgraded to and the cost.Comment
Go to control panel, open mouse properties, go to the pointer options tab, then drag the pointer speed bar all the way to the right. Hit apply then ok. That'll speed things up.
Just kidding...
+1 for CCleanerComment
It could be a number of things mate but usually after a few years XP will degrade to such a level that all the cleaning in the world wont help.
All versions of Windows suffer from this although from Vista onwards Microsoft have produced methods to slow it down but not stop it..
XP was terrible for degradation and if you have changed programs often or its poorly maintained then a pc can be crippled in just over a year..
The only proper solution is a clean install, this means getting a good copy of your OS, backing up drivers and data, nuking your hard drive and starting from scratch..
I done a pc with very similar spec to yours yesterday for a customer with a old HP laptop, it was crippled but had no Malware on it..
Opening MS Word took 2min and to open Outlook was near impossible, after a clean install it ran sweet as a nut..."Windows - A thirty-two bit extension and GUI shell to a sixteen bit patch to an eight bit operating system originally coded for a four bit microprocessor and sold by a two-bit company that can't stand one bit of competition."Comment
Me i can recommend the use of the spybot search and destroy to check if there are no spyware present on the pcComment
