ram help please
  • victor1
    • Oct 2008
    • 83
    ram help please
    I have an Asus P5KPL/EPU motherboard, there is 4 1gb of OCZ ram in each bank, but the board is only recognizing 2 gb anyone offer advice on how to get the other 2bg of ram to show ? I have the latest Bios
  • victor1
    • Oct 2008
    • 83
    cpu-z shows the following:
    RAM : 2048 MB DDR2 Dual Channel
    RAM Speed : 399.5 MHz (1:2) @ 5-5-5-15
    Slot 1 : 1024MB (6400)
    Slot 1 Manufacturer : OCZ
    Slot 2 : 1024MB (6400)
    Slot 2 Manufacturer : OCZ
    The ram in all four slots is exactly the same ocz
    • 03ahmads
      • Jun 2011
      • 150
      Try removing the Ram & reseating. Also try loading the default settings on the motherboard. What OS are you running? 32 bit Windows will only see 3gb of ram, 64 bit is required to make use of any additional ram. Let us know how you get on.
      • victor1
        • Oct 2008
        • 83
        windows 7 64bt, tried your other suggestions numerous times.
        • ray156
          • 669
          4 x240-pin DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Memory
          Dual Channel memory architecture
          *Support max. 2 DIMM modules only for yellow DIMMs when over-clock to DDR2-1066
          *When installing four DDR2 DIMM modules, install only single-sided memory modules
          • Cod3waX
            • 1011
            yea soz ray i should really wake up first before trying to solve peoples comp probs
            the other 2 slots are simply just not enabled in the bios
            so what u have to do is pop into ur bios and remap the memory
            You have to find the memory remapping functionality that is super hidden inside CHIPSET CONFIGURATION / NORTH CHIPSET, enable it and it will this will give u 4GB
            • ray156
              • 669
              Originally posted by Cod3waX
              this isnt ur new board with ddr2 and ddr3 slots?
              nah.thats the specs for board thread is about,he only getting 2gb.
              • victor1
                • Oct 2008
                • 83
                Just done that cod, still no luck though strange this
                • ray156
                  • 669
                  i still refer to line 4 of my 1st post.as OCZ is double sided.
                  • victor1
                    • Oct 2008
                    • 83
                    I'm not totally savvy with what your saying bud, but I take it you mean the OCZ ram cannot be used by me then ?
                    • Cod3waX
                      • 1011
                      well yes and no
                      is ur ocz ram double sided?
                      if this is the case then u must buy 1 chip sided ram
                      never heard of this myself
                      the only other think ive heard as-well is that windows uses the ram from the gfx card and then from the ram module making it up to 4gb usage
                      are u using a 2 gb gfx card?
                      • victor1
                        • Oct 2008
                        • 83
                        no to the gfx
                        double sided ? I'm not sure what is meant by that, sorry if I sound like a numpty
                        • victor1
                          • Oct 2008
                          • 83
                          OCZ DDR2 PC2-6400 Platinum Revision 2 Dual Channel *EOL - OCZ
                          • ray156
                            • 669
                            as what i said......
                            your board works with dual channel but only using 2 slots.
                            if using the 4 slots it must be single channel ddr2.
                            go there-specs-memory.
                            ASUS - Motherboards- ASUS P5KPL/EPU
                            • victor1
                              • Oct 2008
                              • 83
                              Right, do all the sticks of ram have to be single channel then, what if I had 2 1gb sticks of single chnl in with the two sticks of dual channel ?
                              Thanks for all the help folks I really appreciate it
