I have an Asus P5KPL/EPU motherboard, there is 4 1gb of OCZ ram in each bank, but the board is only recognizing 2 gb anyone offer advice on how to get the other 2bg of ram to show ? I have the latest Bios
ram help please
yea soz ray i should really wake up first before trying to solve peoples comp probs
the other 2 slots are simply just not enabled in the bios
so what u have to do is pop into ur bios and remap the memory
You have to find the memory remapping functionality that is super hidden inside CHIPSET CONFIGURATION / NORTH CHIPSET, enable it and it will this will give u 4GBAttached FilesLast edited by Cod3waX; 21 August, 2012, 12:17.Comment
Just done that cod, still no luck though strange thisyea soz ray i should really wake up first before trying to solve peoples comp probs
well yes and no
is ur ocz ram double sided?
if this is the case then u must buy 1 chip sided ram
never heard of this myself
the only other think ive heard as-well is that windows uses the ram from the gfx card and then from the ram module making it up to 4gb usage
are u using a 2 gb gfx card?Comment
as what i said......
4 x240-pin DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Memory
Dual Channel memory architecture
*Support max. 2 DIMM modules only for yellow DIMMs when over-clock to DDR2-1066
*When installing four DDR2 DIMM modules, install only single-sided memory modules
your board works with dual channel but only using 2 slots.
if using the 4 slots it must be single channel ddr2.
go there-specs-memory.
ASUS - Motherboards- ASUS P5KPL/EPUComment
