have u cleared the cmos?
pc wont boot
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'.Comment
Take the battery out that looks like a watch battery and leave it out for an hour or so . Or see if theres a jumper on the mobo to clear the cmos. It should tell you in the motherboard manual sorry bulldog for calling you mobo,dont know how i managed thatComment
Do you still have the support cd that come with the motherboard?
Also unflug everything apart from GFX card and RAM, anf if poss try another GFX Card with the original ram in, clear the cmos on the board:
If you want to erase CMOS...
1. Turn off the computer and unplug the power cord.
2. Remove the battery, wait for 30 second.
3. Re-install the battery.
4. Plug the power cord and turn on the computer.
Also check page 17 of the manual, tells you how to do it bu jumper.
Check all fans are correctly fitting, if there is any posts from the bios, enter and turn off chasis intrusion. Also load failsafe defaults.Last edited by cunny; 23 May, 2009, 06:22.sigpic
If you can get into bios setup. Check this out
FDRAM Clock (MHz)
8Please set DRAM Clock according to your requirement. (Default value: Auto)
If you use DDR266 DRAM module, please set "DRAM Clock(MHz)" to "133-DDR266". If you use
DDR333 DRAM module, please set "DRAM Clock(MHz)" to "166-DDR333". If you use DDR400
DRAM module, please set "DRAM Clock(MHz)" to "200-DDR400".
Incorrect using it may cause damage to your system your system.
