pc wont boot
  • spondulick
    • 677
    pc wont boot
    upgraded memory on my pc, added 1 gig ddr pc32oo, there was already installed 512 mb ddr pc 2700,tried to boot pc all that happens is i get a beeping sound from my pc,i have removed the upgrade and still i have the same symptoms. has anyone got any ideas how i may rectify this problem if possible.
    Have you knocked the other stick when putting the new one in. Check the ram is seated correctly.
    • cgscott
      • 3513
      The rams must be of the same cache. Speed. You sayin they are 2 different Ram Modules.
      2700 and 3200?
      Patience is a virtue.
        They will work together but will run at the lower speed.
        • cgscott
          • 3513
          Try running it with only your new ram see if it boots.
          • cunny
            • 4915
            Put the 1 gb in dimm slot 1 then the 512 in the other next to it.
            Continous beeps (depending on boards) either means video or memory fault
            • spondulick
              • 677
              thanks for your replies,i have tried every config, but still get same result my mainboard is gigabyte model 7v7600rz.
                Have a look on gigabyte website for mobo beep errors m8. At least you will know where the problem is. As cunny saoid it may be a graphic card error
                • spondulick
                  • 677
                  cant find anything on website for mobo beep errors,, 2 beeps pause two beeps and so on.
                    Doing a quick google m8 it does appear to be constant with a ram error
                    • cunny
                      • 4915
                      Whats the bios type?
                      I have searched for your board are you sure its the correct model number.
                      Do you still have the motherboard cd?
                      • mindcrime
                        • 63
                        pc won't boot
                        check that the memory is correct type i.e non eec or eec
                        • spondulick
                          • 677
                          my motherboard is 7vt 600 rz sorry about the delay have had trouble with internet con
                          • cunny
                            • 4915
                            This is the manual for your board
                            I would clear the cmos, instal the 1gb nearest to the cpu, then power up, see how that gets you. If still same then do same for other dimm (how it was originally)
                            • spondulick
                              • 677
                              sorry to mess u about but sound is beep pause beep pause and so on
