how to speed up computer
  • nevovx
    • Aug 2009
    • 156
    #16
    Originally posted by caveman_nige
    what shop do you work at, need to know so as to avoid it
    We should of have rating system in here Great answer as i was about to type something similar untill i saw your post.
    • mickyboy
      • 524
      #17
      try the basics first m8ty disc clean up and a defrag
      • Street Hawk
        • 156
        #18
        Nevovx, i have never EVER known a computer to run slow because of photo's & music on it? its almost like saying the computer will run slow if you have microsoft office on it or anything else on your computer other than windows? sorry fella i have to TOTALLY dis-agree with you on that one.
        a good system cleaner will do, general clear out of crap on your machine, pretty much what everone else has said, cookies etc & i would advise keeping an eye on what your installing buddy, we have all done it in the past where you get a new bit of software or downloaded some software & hit the "Next" button right the way through without un-checking the little box that says "keep this ticked if you want to install the famous spyware tool bar" haha .. even i have done it & thought.. Grrrr have to trace the install of & un-install it again!
        • Magser
          • 15
          #19
          Ryan, while I like some of the advice, some is akin to the help Pilot gave the great man,in all probability you have a P C like us all, just basic with the bare minimum of all that we should have masses of but fiscallly we are fortunate to have anything at all,Reve uninstaller will allow you to stop all running programmes that are not needed and will delete all rubbish that is left after uninstalling any programmes,Baku will help sort out any rubbish on your P C and Window Washer will also help they are all freebies try them they have helped me also get an external drive and save any downloads onto it so saving your internal Hard-drive,another freebie AVG is an excellant protection,hope this helps Enjoy
          • mattj
            • Aug 2009
            • 4
            #20
            There are various simple things such as de-fragmentation or clearing your cookies which may help. Try this article from Microsoft on 5 ways to speed up your computer - microsoft.com/atwork/getstarted/speed.mspx
            Matthew
            HP laptops
            • davem
              • Aug 2009
              #21
              My pc has been extremely slow i have done loads of scans i run norton 360 which i thought was slowing things up nothing seemed to work, However i have switched my home page from google and installed google chrome and used the short cut from the desk top to fire things up its like lightning now
              hope this helps
              • pavel332
                • Aug 2009
                If your computer works very slow you must format your hard disk and install Windows...
                • marlger
                  • Aug 2009
                  • 10
                  #23
                  slow pc
                  get a prog called System mechanidc pro, its a great wee bit of stuff, also if u are using norton I personally would dump it for something ,always found it slowed things up, Sys Mechanis will doo most things to get u up faster at the click of a button, ucan even dload a trial version at Iola
                  • deckster
                    Computer Slow
                    What operating system? How much RAM?
                    • 0oxangelxo0
                      • Dec 2012
                      #25
                      The easiest way to speed it up would be to take it step by step to clear it out.
                      - Anti virus scan (any anti-virus software works fine)
                      - Delete any programs you don't use, they are just taking up space.
                      - You could take it to a computer specialist who will clear it out and speed it up super fast.
                      - Or get the speed up my pc program - it works
                      • dixie74
                        • Feb 2011
                        • 222
                        #26
                        i didnt use my pc for a long time.it was put in the garage covered up in plastic bin bags.however had lots of dust inside when i took the sides off try cleaning inside if you havnt already.just a thought.
                        • vodila
                          • Dec 2012
                          yes its realy men
                          • ajax2061
                            • 395
                            #28
                            9 out of ten times this due to crap installed/malware
                            1 give it a malwarebytes full scan
                            2 run ccleaner or glary utls to clean up the crap, whislt in one of these clean up what programs startup with windows and turn off whatn you do not need eg updaters phone software etc etc
                            3 if slow on the net uninstall toolbars
                            tbh a defrag helps a touch but not that much that it needs to be done every month, a few times a year is enough for most pplm unless your constantly installing/uninstalling move or deleting data.
                            • m9g
                              • 704
                              #29
                              I agree with cunny, what part is slow?
                              How much ram have you got, this IS the first step to make any pc faster = for all we know you might be running windows 95 with 32meg of ram thus making all the above suggestions non-applicable although they are all correct for improving speed
                              DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
                              • Cod3waX
                                • 1011
                                #30
                                how much room do u have left on ur c drive??
                                the first trick of buy a new computer is to partition ur hdd so that u can save all ur music photos vids apps etc... into this new partition and stop clogging up the C: drive
                                windows likes free hdd space to allow the system to move quicker/move things quicker
                                almost acting like ram
