could some one guide me on how to re-set a laptop using vista, i do not have a CD containing vista as the laptop came with it installed.. thanks...
vista re set?
On some laptops the os is installed on a seperate partition on the hard drive . Instructions should have come with laptop, if not google your model. If you cannot find any info maybe do a system restore to an earlier date. Apart from that you are going to need to get your hands on a disc with Vista on.
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'. -
Is there an application on the laptop to create the restore disks? HP and Toshiba normally have a "Create Recovery Disks" icon in the Utilities or Toshiba folder that you can run - you then insert DVD / CD media as appropriate and follow the instructions (took about an hour on the Toshiba L300 I downgraded to XP this morning).
SpaceratComment
sometimes u have to press f11 or f10 repeatedly as its bootingany information provided is for educational/experimental purposes only.Comment
