hi just got new printer with cis system the ink cartriges do not fill while printing it empty's them completely. then i have to fill them manually. does anyone have the same pro or know what's wrong thanks.
I had a very similar problem when i was buying mine, both from same seller, ended up binning old cis and getting new 1 off of flea bay for ?20
l have a r256 at work that has the old cis (auto reset) but my rx560 has to have the latest chip to reset , but u have to reset with a little button the ciss system as they remember the ink cartridge
i had a similar set up on the 265 but when it gave up the ghost i bought a 285, the ciss i have on it wont auto refill and if your half way through print you practically write it off if a photo or a disc being printed
thanks for info. i manually filled the ink cartridges because they were empty when i got them, printed 30 sheets of a4 paper 25 sheets ok then on the 5 prints washed out checked the cartridges empty of ink. some one told me the cartridges stay full all the time its supposed to top them up as you print
true m8 .. l dont do that with mine . have u got the ink on the same level as the printer ?
my system dosn't seem to draw any ink into the cartridges when i do a head clean do you think it could be a chip prob m8 or am i missing something. cheers
Reason: missed out some words
