dell latitude d630 admin password ??
  • Petegolfer
    • Aug 2011
    • 8
    #886
    Originally posted by smoggy
    it is a Dell laptop
    you have typed them in the correct case as tags and passwords are case sensitive
    the only other one I can calculate is t8bwE43e6tTeA77n make sure you type them in as the case they are printed
    This didn't work either. I am typing everything in correctly
    • smoggy
      • Apr 2009
      • 12772
      #887
      what is the make and model of your laptop
      serial tag ending -1D3B is not a valid Dell serial
      • Petegolfer
        • Aug 2011
        • 8
        #888
        If it's not a valid Dell tag, then maybe I'm wrong.
        The sticker days DPPP5Q1 and it also says DPPP5Q1 in the BIOS. The -1D3B shows up at the service tag for windows preboot login.
        Perhaps you can please give me the master password for DPPP5Q1?
        • smoggy
          • Apr 2009
          • 12772
          #889
          • Petegolfer
            • Aug 2011
            • 8
            #890
            It's a Dell E6420 Latitude
            • smoggy
              • Apr 2009
              • 12772
              #891
              I have given you all the possible passwords so maybe your model cannot be done with this calculator
              only other thing I can suggest is to try resetting via the jumpers or the paperclip method (google is your friend)
              • Petegolfer
                • Aug 2011
                • 8
                #892
                I was looking the other day for the chip but couldn't find it. I'll look again and do the paperclip 3/6 pin method
                • smoggy
                  • Apr 2009
                  • 12772
                  #893
                  search YouTube for dell bios paperclip method
                  • MrFug
                    • 880
                    #894
                    The points your looking for are usually under the RAM chip. You can even bridge them with a flat screwdriver. You might encounter a locked HDD after passing the BIOS.
                    • Rudy100
                      • Aug 2011
                      #895
                      Hi all,
                      i am new to this;
                      but i bought 2 laptops ;
                      a D610 and latitude 13 but both do have the Same admin/setup password on it?
                      can someone please help me to recover these passwords?
                      D610: ST: H Z C 54 Z J -595B
                      Latitude 13: ST: D L C L 5 L 1 -2A7B
                      hope this is enough info..
                      if i get the passwords then i just need to fill it in the normal admin password menu?
                      thanks in advance!
                      • ceylan68
                        • Aug 2011
                        #896
                        thnks hays i have more learn
                        • smoggy
                          • Apr 2009
                          • 12772
                          #897
                          Rudy100
                          H Z C 54 Z J -595B password 4ytlik0q (7th is a zero)
                          D L C L 5 L 1 -2A7B password 99YcPBSprzgoyctR (note there are changes from lower to upper case also 12th is o for orange)
                          • Rudy100
                            • Aug 2011
                            #898
                            Rudy100
                            can you please recalculate the first service tag;
                            i made a mistake; the last Z should be a 2
                            Thanks alot the second one works correctly!
                            • smoggy
                              • Apr 2009
                              • 12772
                              #899
                              that would be 3au9l43e
                              • Tjaan
                                • Aug 2011
                                Can u please help me?
                                Greets
