im trying to connect my spy camera pen by usb but my pc wont pick up anything no icon nothing not even connected device like its dead to respond i also reset the button on the pen cam but still nothing i wonder if anyone can help plz
spy camera pen
DW190
I had a problem like that myself. Had it working for a while and then it wasn,t kicking in on the usb, couldnt switch it off either.
I left mine on until the battery flattened and then left it in the usb overnight to charge. Day after was working again fine and being recognised on the usb.
I have a disc for mine using XP but it sorted itself out on Vista.Comment
These camera pens, along with "yum-cha" MP3 players use cheap memory chips and the rest of the hardware/firmware is not very fault-tolerant. I suspect you may not be able to revive it.
BTW, spy camera pens generally show up as mass storage devices and don't need drivers.
Try pushing down the record, or power button while you insert it into the USB. This may bring up the service mode, allowing you to update the firmware?? It doesn't matter if you don't have the firmware - any sign of life is hopeful.Comment
