pc freezing
  • andy4
    • 1125
    pc freezing
    every time i'm on pc it keeps freezing after bout 1/2hr
    can't log off or shut anything down only way is to switch power off then power up again i've got AVG upto date & i clean & defrag regular can anyone shed any light on this
    WIGAN ATH the BLUE BRAZILIANS
    DWSTADIUM the theatre of SCREAMS
    <<<<--------if i've been helpful hit the Thanks button
  • ruudvandan
    • 1091
    soundds like a hardware problem. I would start by checking the memory. I would remove one memory module and see if it happens again, if it does then put the module back in and remove a different one, repeat this until you have tried it without each of the memory modules.
    http://www.facebook.com/BoycottFIFASponsors
    • mandos
      Most likely its the CPU fan - open the case and see if it works. Usually when the CPU fan stops, CPU temperatures rise after 30 min-1 h depending on the CPU usage, and the CPU stops working.
      • dik
        • Apr 2009
        • 955
        I have had this problem on my home pc drove me mad for months, tried different ram, swapped the cpu, added more fans, changed the graphics card, eventually gave up and built a new pc, then used one of the hard drives (400 gig that had just been used for storing media) on my work pc and got the same thing happen on that, 400 gig hdd now in the bin!
        sigpic another happy customer
        Sent from my keyboard using fingers to type
        • andy4
          • 1125
          found out it was the old harddrive i put in last year
          all sorted now thanks for all your help
          • fifii69
            • 81
            Use this speedFan
            SpeedFan 4.39 - V3.co.uk - formerly vnunet.com
            and you can check what procesor has got temperature.
            If temperature still will heighten , problem is with your cooling.
            If temperature will be stable you can be sure it is not cooling problem.
            Please check and let me know what temperature your processor has
            • cunny
              • 4915
              Andy, try changing the IDE/SATA leads on the drive. If not, find make of the drive, goto thier site and you can download utility's for the drive.
              • andy4
                • 1125
                put new harddrive in tower thrown old one away after setting bout it with BIG HAMMER
                • Reapers
                  • 242
                  1.use strong security suites (scan in safe mode to make sure of removal of the threats to your pc)
                  kapresky
                  symantec endpoint
                  spyblaster
                  spysweeper
                  spybot sd
                  2. defragment the hard drive.
                  3. if still continuning you could have bad errors that have created on the hard drive you will either command prompt or recovery console to fix it.
                  start - run -cmd
                  type chkdsk (C:/example)
                  goodluck : )
