hi i am trying to get my pc input on my 42 inch hd ready panasonic plasma to work, i plug the vga cables in and restart the computer, and it all starts to work fine, very clear picture! but then it just disconnects its self? wondering if anybody knew how to help, thanks
pc in put wont work on plasma tv?
the tv will be out of range and you need to see what your doing to adjust. can you have a monitor and tv plugged in?
if so, run dual display and change the outputWavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable
screw you nag3
Maza87: When you say it disconnects, do you mean it go's blank or it returns to a TV picture on another channel.....
As dctyper says change the range.....
Connect to your normal monitor and in 'Display Settings' set the resolution to 800x600 and save... then attach the TV and see if this works.....Last edited by Dirty Dog; 12 December, 2009, 16:23.Comment
my toshiba pc starts up and windows starts to load, on the tv, then tv goes blank and the signal reverts back to the laptop, i have tryed changing to 800X600, same results.Maza87: When you say it disconnects, do you mean it go's blank or it returns to a TV picture on another channel.....
Connect to your normal monitor and in 'Display Settings' set the resolution to 800x600 and save... then attach the TV and see if this works.....Comment
have you set your graphics card up to work with multiple displays?Comment
