25 FREE BIOS PASSWORD MASTER for Fujitsu-Siemens 6X4
  • Lucas09
    • May 2018
    • 4
    #301
    Originally posted by zhirong2534
    nedd password pls
    code is 0222-0588-8019-1201-5462-9011
    Try this: cwk3qiqy
    • Lucas09
      • May 2018
      • 4
      #302
      Originally posted by alkoxide
      Can you guys help me to remove the bios password?
      Fujitsu Lifebook U904
      Hash code: 027D-0724-0075-8548-8992-8387
      Thanks in advance.
      Try this: 0pu4ugqj
      • fuchla
        • Feb 2018
        • 4
        #303
        anyone tried the python code from http://dogber1.blogspot.com/2009/05/...red-bios.html?
        for the siemens-fujitsu 6x4 hash? its supposedly be able to find the 6x4 code, but all i get is errors even after tinkering with the code.
        • Molina
          • Jan 2018
          • 4
          #304
          Hi, could you help me with this hash for Fujitsu Stylistic Q736
          0299-0725-0127-9321-0906-1299
          Many Thanks
          • Hogan1
            • May 2018
            I need Help Celsius H series
            Hello!
            I have the same issue. Can you tell me my password?
            0222-3698-6145-1631-4002-0163
            Thanks already in advance and regards,
            Günter
            • Ateeque
              • May 2018
              • 10
              #306
              hi
              need some help on fujitsu U772
              code is 0222-0668-4037-7931-4341-2258
              • Saymon2017
                • Dec 2017
                #307
                bro can you hel me please 0292-3765-0119-8729-6925-8290 thank you advence
                • Saymon2017
                  • Dec 2017
                  #308
                  0292-3765-0119-8729-6925-8290 can you help me to find maser password please thank you advence
                  • teeaa
                    • Dec 2017
                    • 103
                    #309
                    Many Thanks
                    Hi,
                    Try sdd16b6w
                    -ta-
                    • teeaa
                      • Dec 2017
                      • 103
                      #310
                      Originally posted by Hogan1
                      Hello!
                      Günter
                      Hi,
                      Try cftsvhqp
                      -ta-
                      • teeaa
                        • Dec 2017
                        • 103
                        #311
                        Originally posted by Ateeque
                        hi
                        Hi,
                        Try o2xh89ut
                        -ta-
                        • teeaa
                          • Dec 2017
                          • 103
                          #312
                          Hi,
                          Try o6xxuz2t
                          -ta-
                          • gitarock
                            • May 2018
                            #313
                            FUJİTSU AH532 0F17-0697-0162-6358-5626-1155 TEŞEKKÜRLER
                            • gitarock
                              • May 2018
                              #314
                              I want to share with you how I learned how to change the end result of friends busy work.
                              Firstly
                              write down the codes on the incoming bios screen
                              First password: 3hqgo3
                              Second password: jqw534
                              Third password: 0qww294e
                              it will give you the bi code.
                              sample :
                              XXXX-XXXX-XXXX-XXXX-XXXX-XXXX
                              THIS CODE
                              Synopsis: The mechanics of BIOS password locks present in current generation laptops are briefly outlined. Trivial mechanisms have been put ...
                              download this 6x4 file on this link (pwgen-fsi-6x4dec)
                              To open the file:
                              https://filehippo.com/download_python/4744/ download and install this program.
                              Click and open pwgen-fsi-6x4dec and type in the code your computer gave to the cmd command that will open. )
                              • vandersell
                                • Jun 2018
                                • 8
                                #315
                                Originally posted by Talleresmalaga
                                Fujitsu stylistic Tablet Reset unlock BIOS password hash código 6x4
                                Here you can get your master key, for Fujitsu-Siemens Decimal Digits 6X4
                                during the next 2 weeks you can request your free master password, up to 25, 1 per registered member
                                as?
                                When asked for a password, enter these:
                                You will receive a hash code with 6 blocks, each with four numbers,
                                eg 12c4-4321-1234-4321-1234-4321
                                [ATTACH=CONFIG]491524[/ATTACH]
                                Attach this number to generate your master password
                                Be careful, every time you speak the previous codes Hash and master password change
                                regards
                                Lifebook U904, oversecured by self (and bios pwd lost) ;-(
                                Code: 027d-3951-4039-1621-0394-4995 (all digits apart from d)
                                Any help appreciated. Thanks!
