cant delete mkv files?
  • j4p
    • 7
    i downloaded a movie in mkv format (4.5 gig) and cannot delete it,i am on windows7 and have tried various ways. any help would be greatly appreciated.
  • snagga
    • 167
    1. The obvious would be to, shutdown computer and restart, then try deleting it again.
    2. Make sure the file download is completed, if not kill the download and try to delete.
    3. Check task manager to make sure file not in use.
    • j4p
      • 7
      the movie download is complete and plays. restarting makes no difference.when i press delete a popup box appears and says-preparing to recycle and underneath that it says-from discovering items and a coloured bar moves across the box constatntly for hours on end. i tried to google the problem but cant find an answer that works.
      • snagga
        • 167
        Did you try to boot into safe mode?
        Also try to run msconfig and and disable all services and startup process, then reboot and try again.
        Make a note of all your services and startup currently active, before you disable them
        • MxWill
          • 68
          this soultion worked for me
          right-click on the file, select Properties, then under the General tab select the Advanced button for Attributes, then uncheck both options under the File Attributes section ('File is ready for archiving' and 'Allow this file to have contents indexed in addition to file properties'). After applying these changes, the file can be instantly deleted.
          • j4p
            • 7
            when i right click then click properties nothing at all happens. i am going to try the msconfig way now.i will let you know.
            • j4p
              • 7
              no joy. i rebooted in safe mode and deleted it to recyle bin now i cant empty recycle bin!
              • j4p
                • 7
                success. rebooted again in safe mode and emptied the recycle bin and it appears to have worked..thanks for your help
                • snagga
                  • 167
                  Glad it worked out for you.
                  • Itsme
                    • 187
                    If you have this trouble again there are several utilities available for deleting locked or in use files but I dont have win7 so dont know if they are compatable,
                    Google for
                    File Assassin
                    Move on Boot
                    Unlocker
                    Hope this helps for future reference
                    I believe also that in Win7 some file installs and deletes depend on the users permissions but I am not sure about this.
                    • kashifg323
                      Good post
                      very good post and much informative
                      • my8kitso
                        • Aug 2011
                        FYI, this didn't work for me. I was able to uncheck the boxes, but still unable to delete the MKV files. Sigh.....
                        • happy_highlander
                          • 3535
                          download and install delete dr (doctor) and select delete on reboot for the appropriate file then just reboot it will be gone
                          • arunkumar1997
                            • Aug 2011
                            install this software then right click on the file you wanted to delete then select unlocker and then unlock all processes using that file then delete the file
                            Unlocker - Free software downloads and software reviews - CNET Download.com
                            • andy211081
                              • 575
                              how was the mkv downloaded? from the net or via a torrent utility?
                              Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
