disk c has too many rubbish .i do not know which file i can delete
PC work slow
have a good read through some other posts mate there are loads on this subject....
You should only delete programs from within the "add/delete programs" reached through the control panel.
You can also do a disk cleanup, which you can get to from the start menu and system tools. which will allow you to delete cookies, temp files and empty your trash bin etc
The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the worldComment
If you do that important things that should start (like your antivirus) will not run, look to see what crap is starting with windows and disable itsigpic
another happy customer
Sent from my keyboard using fingers to typeComment
download superantispyware ( its free) and do a complete system scan
ccleaner as Dasteph suggests is one I use as well for clearing all the crap out of your system, it also incorporates a registry cleanerComment
another thing to do is go my computer,click c drive,click search and select the photos and video selection,after the search is compleet look at all your pictures you want to keep along with all your videos and copy them to a disc,you can do the same wyth your music,after that format your drive and do a new instalation,it should now be like new,,mind and make sure you have all the drivers that you need to get it running again,good luckComment
, remove unneeded background services ....
